R50/53 clearcoat peeling
Old Jan 15, 2017 | 10:46 AM
coopermike29's Avatar
coopermike29
clearcoat peeling
Has anyone experienced this and in what area ?
There was a mention on another non-related thread.
I thought I would start and dedicate this this subject.
Would love some tips on how to do.
Searched the internet...and found a FEW that were pretty good....MOST were junk !!!!
I have a few areas ......drivers side lamp area....... door handles( concave area)
Hood...near the wipers..about the size of a small summer squash.
I just sprayed the areas with some topcoat so it wouldn't peel any further.
Its winter up here in MA....and we had a day last week that was near 60 !!!
VERY rare !!!!
Will do the job right in the Spring when weather is warmer !!!!
Old Jan 15, 2017 | 10:59 AM
iwashmycar's Avatar
iwashmycar
What is your detailing schedule like?
Which color do you have?
Wash it often?
When do you wax it and with what? Any machine polishing done?
All OEM paint?
I dont have a fix, besides repainting, but I am more curious about the how and why lol
Old Jan 16, 2017 | 05:10 PM
coopermike29
I keep my cars in excellent condition inside and out.
I believe its because of a cheap paint job.
The interior is in excellent condition and no leaks, which for me is the most important.
Old Jan 17, 2017 | 06:30 AM
iwashmycar's Avatar
iwashmycar
Ah, well then it likely wont stop. Any repair would probably be met with new spots flaking. You will likely need to respray it all or at least what was repainted before
Old Jan 17, 2017 | 06:14 PM
rough68fish's Avatar
rough68fish
I had peeling clear where the car was repaired several years ago. I have had to have other cars repaired and haven't had this problem before. I think it's because in MD they have to use water based color and at that time it was pretty new. I'm currently having the car totally repainted in PA where they can still use polyurethane color and clear.
Old Jan 18, 2017 | 01:13 PM
coopermike29
I believe we also have poly here in MA!!
If not...NH is only an hour away...........
Thanks for all the replies.....
Old Jan 19, 2017 | 04:55 AM
Capt_bj's Avatar
Capt_bj
Have done some body repair and repainting
5 years is not an unusual life span for the clear on a repaint, water or petroleum based ....
unless the prep and conditions are 'perfect' when the clear is laid down, delamination is far from uncommon ..... this why I sometimes suggest 'living with' a small blemish as the repair may be worse in the long run ....
Old Jan 19, 2017 | 11:52 AM
mdaz75's Avatar
mdaz75
CooperMike, where in MA are you?
Old Jan 23, 2017 | 12:39 PM
coopermike29
20 minutes north of Boston
Essex county..
Where are you located ?
Old Jan 23, 2017 | 03:38 PM
mdaz75's Avatar
mdaz75
I'm just outside of Worcester.
Old Jan 24, 2017 | 11:28 AM
coopermike29
Plus 1 ^ capt_bj !!!!!!!!
I removed the loose peeling on the hood and sprayed with clearcoat.
Doesn't really look that bad. From a short distance .....can't even tell
Thanks again for all the replies !!
much appreciated !!
