Diameter witdh and specs 15' Hollies
OEM tire size is 175/65-15
You can easily put on 195/60-15, this fits rims 5.5-7" wide and has tire diameter of 24.2" which is OEM. Load rating is 88 which is better than OEM. You can choose from H Speed rated or higher tires like V or W. Tire selection is better in this size.
Alternatively 185/65-15 or 205/55-15 will also work.
Contact Alex@tirerack.com for tire choices and more info on fitment.
You do not need to use OEM 175/65-15 tire size.
