FS:: Advanti HY Hybris 17x7.5
Category: Wheels & Tires
Price: $500
Location (Region): Midwestern
I bought these wheels from tirerack mounted with winter tires but they will NOT fit over JCW brakes without a spacer. With a 5mm spacers they BARELY clear the brakes with about 0.5mm clearance, so they really need an 8 or 10mm for JCW models, but will be absolutely perfect for any other F55, F56 model. Another great advantage is the hub is 65.56 so no centering rings required. I absolutely love the wheels but having an effectively ET35 (with spacer) with a winter setup concerns me due to meat of the tire and poke beyond sidewall. If I was running these with summer tires at a 35/40 profile I would definitely keep them.
Price is $500 for the wheels only +shipping. The tires you see in the pictures will be removed and installed on a track spoke wheel. These wheels were never driven on - only test fitted as you see in the pictures.
Thanks for looking,
Kevin
