R56 Accuse a bug in my mini cooper r56
Old Dec 4, 2016 | 07:44 AM
Johnny Freitas's Avatar
Johnny Freitas
Good appears the following error in my computer board, the following already filled the liquid of the clean glass is full and he is always saying to me that this low what I can do to erase the error?
Old Dec 4, 2016 | 11:51 AM
cerenkov's Avatar
cerenkov
Have you check to see if the sensor came unplugged?
Old Dec 4, 2016 | 03:28 PM
Johnny Freitas
I went to the water tank to see if the plug was connected to the sensor and yes it is connected, is there another part where to turn off this sensor? Is it because I'm not really seeing how to solve this or is it what sensor is damaged?
Old Dec 4, 2016 | 06:29 PM
JCdubGerm's Avatar
JCdubGerm
Those sensors go bad here and there. It's probably bad. If that doesn't fix it there is a pinches wire somewhere . You can get rid of the message without fixing .
Old Dec 5, 2016 | 10:38 AM
Johnny Freitas
How do i get rid of the message if it can not delete with reset
Old Dec 5, 2016 | 01:32 PM
JCdubGerm's Avatar
JCdubGerm
Did you replace the part? It's not going to reset if you don't fix it. Are you sure the tank isn't leaking ?
Old Dec 9, 2016 | 07:26 AM
MiniToBe's Avatar
MiniToBe
can you remove the plug and short the connector to see if the warning light goes away?
