R56 Can someone help me trouble shoot P0001 and misfire codes
Old Dec 2, 2016 | 09:08 AM
iron1951's Avatar
iron1951
I have a 2010 Cooper S and my OBD reader returns p0001 p0300 p0303 p0304 and p0301. I have just replaced the sparkplugs. The check engine light goes on and off. Any idea on how to chase these codes down? I am guessing that the engine misfires could be caused by the p0001 -> "fuel volume regulator control circuit open". I did disconnect the battery when I changed the thermostat housing because I found it easier to get PCM wires out of the way. Help would be appreciated. Thanks.
Old Dec 5, 2016 | 10:47 AM
nkfry's Avatar
nkfry
Sounds like you may have a failing HPFP, have you checked fuel pressure numbers?
If MINI of Canada is under the same warranty as MINI USA:
You can call the dealer to see if your car is covered under the HPFP warranty, if so you'll get it replaced free of charge.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 9, 2016 | 07:28 AM
MiniToBe's Avatar
MiniToBe
start the car and unplug the HPFP and see if the car dies or not. if it does, the pump is good.
Old Dec 9, 2016 | 04:56 PM
iron1951's Avatar
iron1951
If the pump is bad and I unplug it while the car is running, what can I expect?
Old Dec 9, 2016 | 05:24 PM
MiniToBe's Avatar
MiniToBe
When i did that on my 08 clubman s, the car remained running. When you give it gas it will shut off too.
gcaspelich
Dec 24, 2016 11:31 AM
