FS:: Alta Performance AMP-INT-211 Boost Port Adapter R56 Mini Cooper
Old Dec 1, 2016 | 08:16 PM
phillipcoopersgates's Avatar
phillipcoopersgates
Price: $40
Part fits (you may select multiples): R55, R56, R57
Boost tap end was drilled out for a straight exit.
Pictured. Still works 100%.
$40 shipped
Alta Description:
Don't want to drill a hole in your intake manifold to get a boost source for a boost guage? Our boost port is an easy way to get a boost source with out having to make irreversable changes to your intake manifold! Simply remove your intake and plug into the map sensor and you're ready to go!
Attached Thumbnails Alta Performance AMP-INT-211 Boost Port Adapter R56 Mini Cooper-img_4395.jpg   Alta Performance AMP-INT-211 Boost Port Adapter R56 Mini Cooper-img_4397.jpg
