? re: dipstick tube o-ring
Old Nov 29, 2016 | 08:10 AM
JAB 67's Avatar
JAB 67
I am installing a new dipstick tube o-ring (p/n 11437513891). However, I am unsure as to which of two recesses at the end of the tube the o-ring should be placed. Did a search but found no description or picture. TIA.
Old Nov 29, 2016 | 09:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The dipstick o-ring seals the tube to the block. For the o-ring, 11-43-7-513-891 is #11 on the diagram below. Hopefully that helps. Let me know if you have any questions.
888.280.7799 | 6am - 5pm PST
Old Nov 29, 2016 | 10:05 AM
JAB 67's Avatar
JAB 67
It does not help. The crankcase end of the dipstick tube has several circular recesses. My question is, into which recess does the o-ring go?
Old Nov 29, 2016 | 10:14 AM
PelicanParts.com
Vendor
At the end of the dipstick guide tube it should go on the very last indented area, closest to the attachment point to the block. Not my image, but hopefully it will help give you a visual. Review the white arrow pointing to the location of the o-ring:
Old Nov 29, 2016 | 10:43 AM
JAB 67's Avatar
JAB 67
I'm sorry but it still isn't clear. Does it go into the recess that is closest to the opening, or closest to the attachment point?
Old Nov 29, 2016 | 10:52 AM
PelicanParts.com
Vendor
It goes into the recess that is closest to the end that attaches to the block. You see the bracket with the 2 holes near the white arrow? It goes into the recess that is furthest away from that bracket.
Old Nov 29, 2016 | 11:04 AM
JAB 67's Avatar
JAB 67
Clear; thanks.
Old Nov 29, 2016 | 11:42 AM
JAB 67's Avatar
JAB 67
Just figured out my problem. The o-ring I had been sent (and which did not fit at the bottom of the dipstick tube where it enters the crankcase) was for the top of the dipstick, where it enters the tube. Different size.
Old Nov 29, 2016 | 12:23 PM
nkfry's Avatar
nkfry
Just clean everything up really well and use some black RTV, it'll seal better and longer than another O-ring that is going to leak again in a couple years.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
