R50/53 Longer than 1 year between oil changes?
Old Nov 27, 2016 | 06:57 PM
Racingguy04's Avatar
Racingguy04
I normally change my oil every 10,000 miles or every year whichever comes first (it's usually a year) But my car has been doing more sitting than normal this year because I've been over seas since the end August. I'm headed home for Christmas, and then I'll be gone for 12 months.
I normally change my oil in November, so it was last changed in November 2015 with mobil 1 european spec 0w40 synthetic. I didn't change it in August when I parked the car since it was just going to be parked for a few months. My question is, should I change the oil twice in December?
My plan was to drive it when I got home, and then change the oil when I park it, but now I'm kind of having second thoughts about driving it with 13 month old oil, even if the oil hasn't seen many miles (I think 5,000-6,000). I'd also like to not spend an extra $50 on a superfluous oil change.
So as I see it, my options are:
1. Drive on the oil its got, and change it when I park it.
2. Change it when I get home and park it with that oil in it.
3. Change it when I get home, and change it again when I park it
4. Change it when I get home, and change it when I park it but don't change the filter.
What should I do?
Old Nov 27, 2016 | 08:50 PM
Fly'n Brick's Avatar
Fly'n Brick
I'd worry less about the oil and do something about the fuel. You should treat it with something like STA-BIL. Run the engine a bit to get it circulated thru the injection system. Without it the gas will varnish everything causing real problems.
Old Nov 27, 2016 | 11:57 PM
Mini Mania's Avatar
How far you driving it home? 5-6,000 miles is pushing it. Heet or an appropriate additive for the fuel. If tank is low, fill up on highest octane you can find.
Check out our Cyber Monday sales at minimania.com
Old Nov 28, 2016 | 06:34 AM
Fly'n Brick
I forgot about that. otherwise you'll get moisture condensation in the tank, i.e. water. You really don't want water in there.
Old Nov 28, 2016 | 07:23 AM
Racingguy04
Oh, sorry for the ambiguity. I did stabilize the fuel when I parked it so I should be good there. It's also had recent brake fluid flush, tranny fluid change, and coolant change (within the past year or so)
I've driven about 5,000-6,000 miles with the current oil in the car, I'll probably drive at most a 1,000 miles when I get back home to it before I park it again.
Old Nov 29, 2016 | 05:40 PM
Racingguy04
So.... I'm probably good?
Old Nov 29, 2016 | 11:53 PM
Eric_Rowland's Avatar
Eric_Rowland
I'd say yes. Drive it and do the change in December. Do make sure you check the level though. Motor on!
Old Nov 30, 2016 | 04:00 AM
Racingguy04
Thanks! I definitely plan to give it a thorough once over before I pull it out of the garage.
