foamy coolant
Old Nov 27, 2016 | 09:54 AM
victor101's Avatar
victor101
foamy coolant
I have 229M miles on my 2002S. I recently changed the heater core but now find a thick foamy substance in the overflow. The spark plugs are dry. No foam on the dip stick but it needs refilling constantly. Is it a head gasket issue or some other gasket? Thanks
Old Nov 28, 2016 | 08:49 AM
nkfry's Avatar
nkfry
You need to do a leak down test to find out why you are getting thick foamy buildup in the tank.
Chances are either a head gasket, cracked head, or failed oil cooler.
And what needs refilled constantly, coolant or oil?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Nov 29, 2016 | 06:26 PM
victor101's Avatar
victor101
foamy coolant
I add 2 oz oil per 100 miles. I also notice that I am getting a moisture under the drivers mat. But the rug area to the right of the gas pedal is dry. Ugh
My heater is working but I fear winter coming on
Old Nov 30, 2016 | 06:30 AM
nkfry's Avatar
nkfry
That's a significant amount of oil to need to add in such brief time.
Does the car have a sun roof? Are the front drains affixed and not leaking?
Phone:586-792-6464
Old Dec 4, 2016 | 12:04 PM
victor101's Avatar
victor101
foamy coolant
Thank you for the drain lead. got it opened and done.
Head gasket / cracked head repair are beyond my skill set and would cost much more than the car is worth.
I'm not sure that a gasket failure in the oil coolant-oil filter housing is the problem. there are no leaks in that area.
I add oil before traveling and find it gone after 30 miles.
Thinking I should put it up on ebay for parts
