R50/53 Electronics/Ignition Issue
Old Nov 22, 2016 | 10:46 AM
John Trujillo's Avatar
John Trujillo
Hello,
I have been experiencing a bizarre problem with my 2004 Mini. Occasionally, when I turn the car off, the clock and trip odometer will reset, and the engine will not turn over if I try to start the car again. Other times, all of the electronics (radio, int.&ext. lights, door locks, ignition, key fob, everything) will become non responsive. There are times when this will happen and the car will remain unresponsive for a few minutes or hours, but will then come back online for seemingly no reason. The other day though, I turned the car off and everything immediately stopped working - no lights, radio, ignition, etc... Jump starting it brought it back.
I've noticed that this issue seems to occur when I turn the key to shut down the engine. If I quickly turn the key all the way I don't seem to have a problem. But if I turn the key one notch down (to where the engine is off but the electronics are still active) then these problems seem to occur.
I'm at a loss - I'm going to have my battery tested this week but this seems like too random and complicated a problem to just be a battery issue. Then again, I've heard Minis can do bizarre things when the battery is on the way out.
Any insight is truly appreciated. Thank you!
John
Old Nov 22, 2016 | 01:13 PM
nkfry's Avatar
nkfry
Could be a battery problem, body control unit problem, or some sort of ignition switch problem. Lots of diagnostic heading your way, best to find a quality scan tool and start simple.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
