Super charger problems!!!!! Help
Old Nov 15, 2016 | 10:17 PM
ForzaTheKid's Avatar
ForzaTheKid
So my r53 had a ticking noise on my way to work. Wouldn't of drive it but had no option. After work started it and it made a weird griding belt squeal (like gears in a blender). On my way home it felt pretty gutless and could feel power come in it out and can continue to hear the ticking sound. If anyone knows what this is that would be great. Let me know.
Old Nov 16, 2016 | 04:48 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
put hand on sc horn, you will feel it if the problem is there also check crank damper they do the same thing
Old Dec 4, 2016 | 10:53 AM
ForzaTheKid
I had a machanic come look at it and he is pretty sure its the bearing in the alternator. I guess which would kind of make since with belt squealing sound. So hopefully it will take care of the problem
Old Dec 4, 2016 | 12:23 PM
JAB 67's Avatar
JAB 67
Was the mechanic who came and looked at it someone with Gen1 supercharged Mini experience?
Old Dec 4, 2016 | 03:44 PM
ForzaTheKid
No his first time with one but i live in a very small town. I think im the only mini owner in the county.
Old Dec 4, 2016 | 05:12 PM
JAB 67's Avatar
JAB 67
Reason that I ask is because statistically speaking, a bad supercharger is probably more likely than an alternator, at least in my opinion, and if the mechanic is not accustomed to listening to a supercharger death rattle he might assume it is an alternator.
Old Dec 4, 2016 | 05:43 PM
ForzaTheKid
Right. When he said that i was like damn I probably should of noticed the alternator. But thats what he thinks it is so i told him once he has the belt off to turn the sc pulley n if it doesn't make any weird sounds and spins okay then ill just replace the alternator and hope it fixes it.
Old Dec 5, 2016 | 01:21 PM
Lt. Dan's Avatar
Lt. Dan
Update?
Old Dec 5, 2016 | 07:22 PM
ForzaTheKid
Originally Posted by Lt. Dan
Update?
Waiting for the alternator the show up. It was like $100 cheaper to order one. Gunna do 15% reduction pulley also
Old Dec 19, 2016 | 09:57 AM
ForzaTheKid
Update!
So the guy that was going to work on the mini didn't have the clam shell pulley tool or the tensioner tool n asked if i would order the stuff so i did and when it arrives im just going to do the work myself. Got the alternator and reduction pulley. Just waiting on tools now.
Old Dec 19, 2016 | 10:41 AM
MrBlah's Avatar
MrBlah
cool its one of the easier jobs, except for lifting the engine so the pulley clears the frame it was pretty easy
I bet the real problem is the damper
Old Dec 19, 2016 | 11:09 AM
ForzaTheKid
Yeah i watched some YouTube videos n it doesn't seem to bad. And i was gunna replace the the tensioner but hopefully its still good. I guess I'll find out when i get it all apart.
Old Dec 19, 2016 | 11:13 AM
MrBlah's Avatar
MrBlah
I use a damper safety strap, all 3 of my r53 engines have damper shocks that are blown I dunno how long those stupid shocks actually dampen but it can't be very long
Old Dec 22, 2016 | 09:06 PM
ForzaTheKid
well the tools came into today but i dont think ill be able to get to it until maybe monday. I did start it today and felt the sc horn and it had some vibration in it but the sound is coming from below by the alternator so hopefully it is just the alternator. My question is will the horn vibrate from that or does it always have a bit of a vibrate?
Old Dec 26, 2016 | 10:00 PM
ForzaTheKid
Update!
Got the alternator off and it turned real nasty. The sc turns fine so im guessing it was the alternator. I got the new plugs in n then the power went out so ill get the new sc pulley on tomorrow on hope it rips!
Old Dec 28, 2016 | 11:08 PM
ForzaTheKid
Its fixed!!!!
Got the alternator on and it was indeed the problem! Figured sice i had it apart id do all the other stuff. So i put the 15% reduction pulley on the supercharger and new tensioner along with a boost gauge. Glad to have my mini back!
Old Dec 31, 2016 | 05:51 PM
sevin's Avatar
sevin
What boost gauge did you get?
Old Dec 31, 2016 | 07:40 PM
Scooter24's Avatar
Scooter24
Side note, where in Michigan u from?
Old Jan 1, 2017 | 01:40 PM
ForzaTheKid
Glowshift. It was pretty cheap but works great. It changes like 7 different colors am has a color changing setting that cycles through all of them. Seems to work pretty good for not being to exspensive. Building 15lbs roght now.
Old Jan 1, 2017 | 01:41 PM
ForzaTheKid
Gladwin. You?
Old Jan 1, 2017 | 01:45 PM
Scooter24's Avatar
Scooter24
Originally Posted by ForzaTheKid
Gladwin. You?
From durand, about 79 miles from Gladwin.
Old Jan 1, 2017 | 01:46 PM
ForzaTheKid
right on that's pretty sweet!
