R55 alta access port
Old Nov 14, 2016 | 01:30 PM
rajomanic's Avatar
rajomanic
alta access port
Hi all,
I am about to purchase an Alta Access port and wanted to know if my stock parts will hold up or do I need to do other upgrades as well. I drive a 2010 R55 mini cooper clubman JCW. any suggestions would be appreciated.
Old Nov 21, 2016 | 11:21 PM
Absolutjh22's Avatar
Absolutjh22
Yes, your factory components will work. You will only be able to use one of the Stage 1 tunes for a few extra horsepower, but the throttle response alone is worth it. Just make sure and add an oil catch can, consider replacing the turbo oil cooler line as you'll be running the turbo harder, and have your valves cleaned every 40,000 miles. The valve cleaning being the most important.
