Interior light not working
Old Nov 14, 2016 | 12:08 PM
aviaator's Avatar
aviaator
The center overhead interior "dome" light is not working in my 2014 Clubbie. First tried new bulb ... nope. Looked in the owners manual and it talks about turning all the interior lights (footwell and overhead) on or off with that switch on the forward overhead switch cluster.
Is there some setting that the PO might have changed that makes only the footwell lights come on when you open a door?
Thinking I might have damaged the circuit board when I fixed the overhead light rattle but I hope not.
Old Nov 14, 2016 | 01:23 PM
JCdubGerm's Avatar
JCdubGerm
Check the fuse
Old Nov 14, 2016 | 01:43 PM
aviaator's Avatar
aviaator
I will do that but to be clear - this is the only bulb that's not working. All the rest of the interior lights work as they should. I've never seen a car that has one bulb on a fuse.
Old Nov 14, 2016 | 02:20 PM
JCdubGerm's Avatar
JCdubGerm
I know the fuse for the front lights on the roof controls is different from that one. That's why I asked.
Old Nov 15, 2016 | 05:26 AM
MiniToBe's Avatar
MiniToBe
Could the ribbon wire have come loose?
Old Nov 15, 2016 | 07:06 AM
aviaator's Avatar
aviaator
Solved
SOLVED.
I put in an LED bulb when the old one burned out. I did not know that LED bulbs are polarity-sensitive. Turned the bulb 180* in the socket and it now works.
