FS:: 2004 Mini Cooper JCW - performance modified
Year: 2018
Model: Hardtop
Price: $3000
Mileage: 175000
Color: Dark Silver
Location (Region): West
This is a unique, beautiful and fast MINI. I am the second owner, and there were a lot of performance modifications done by first owner. The car does have 175,000 miles and is far from perfect at this point in it's life. But it still has all it's power and drives great. It is a perfect car for a mini enthusiast who wants a low cost fast car, and who is able to put the time into caring for it. This would also be a great track car.
I am located in Oakland, CA. I might be able to drive this car down to the LA area if there is a definite buyer.
INFO:
VIN: WMWRE33474TD84338
Mileage: 175,000
Transmission: 6 speed manual
Aero Kit front bumper and side skirts. Custom black trim. John Cooper Works (JCW) high-performance engine tuning kit (220hp), brakes, suspension and steering wheel. Quaife limited slip differential. Koni struts. Lightweight alloy wheels with brand new performance tires.
The JCW kit was installed at the dealer when new. The kit was upgraded to the 2005+ version by a dealer about 6 months later. This means it has the JCW air intake and uprated fuel injectors.
Well maintained at Bay Bridge Motors in Oakland, CA.
Engine:
High-flow re-usable air filter
ECU tune (~7% increase in hp/tq mid-high rpms) (RMW)
Larger intercooler from JCW GP special edition car (rare OEM part)
Suspension:
JCW front strut bar
JCW springs
Koni "Yellow" adjustable struts
H-Sport "Comp" 25mm hollow rear sway bar
Poly front control arm bushings
JCW brakes with steel lines
Drive train:
Quaife LSD
Short shift kit
Other:
JCW leather steering wheel (thicker and smaller diameter)
Custom black trim
* Team Dynamics PR1.2 with Hankook V12s
* Driver Air Bag
* Anti-Lock Brakes
* Air Conditioning
* CD Player
* Passenger Air Bag
* Rear Window Defroster
* Power Door Locks
* Power Mirrors
* Power Windows
* Power Steering
* Side Airbags
* Sunroof
* Tilt/Telescope Steering Wheel
paint code: dark silver metallic 871
Other extras include:
straight pipe exhaust center section
Spare "donut" wheel and tire
Pair of black Schroth 4-point harnesses that clip right into existing hardware
PROBLEMS WITH THE CAR:
- Cooling system overboils from time to time. I have had this checked out numerous times and the shop says it's not overheating, and the head gasket is good. So they don't know what it is. The overboiling does not prevent you from driving and I don't have to add water very often, so it's really not losing too much water.
- Power locks don't work.
- Side airbags on passenger side are deployed (not the front airbag). This happened when I hit a piece of road debris with the wheel. No body damage and wheel was replaced. I did not bother to replace the airbags.
