18" Tire
Old Sep 17, 2004 | 09:03 PM
MyminicooperS's Avatar
MyminicooperS
18" Tire
What size tire are the best for my 04' MCS 205/40/18 or 215/35/18
Thanks,
Old Sep 20, 2004 | 03:49 PM
Alex@tirerack's Avatar
Alex@tirerack
215/35 - loweing helps fender clearances
Alex
Old Sep 20, 2004 | 03:58 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks,
What wheel are you using? JCW kit 18" or other aftermarket 18"? What suspension do you have? Stock or lowered suspension?
The stock tire for JCW wheels is 205/40-18 but is very limited in which tires come in that size. At tirerack.com there is only the Dunlop SP sport 01 DSST runflat for $255 per tire.
In 215/35-18 there are about 13 tires and it is the usual size to use with 18" rims for the MINI. These would be non runflats. see
http://www.tirerack.com/[font=Arial]a.jsp?a=EZ3&url=/[/font]tires/Compare1.jsp&startIndex=0&width=215%2F&ratio=35&diameter=18&search=true&p agelen=20&pagenum=1&pagemark=1&x=11&y=11
Old Sep 20, 2004 | 05:46 PM
MyminicooperS
18" tires
Many thanks information. Currently I have 3 wheels choice for
my 04' JCW MCS with stock suspension
A) SSR GT1
B) JCW
c) Centerlinewheels
Your suggestion is greatly appreciated
Thanks,
Philip
Old Sep 20, 2004 | 06:39 PM
kenchan's Avatar
kenchan
Is the JCW 18's the same ones that Dave has (below)? if so, this is
the best looking 18's imo.
Dave, I borrowed your signature for the sake of expression (?).
A) SSR GT1
B) JCW
c) Centerlinewheels
Thanks,
Philip
Old Sep 20, 2004 | 07:15 PM
minihune's Avatar
minihune
A) SSR GT1
B) JCW
c) Centerlinewheels
Thanks,
Philip
The JCW is the only MINI 18" wheel at this time and does look reasonably good. Weighs about 23.5 pounds.
SSR comps in anthracite :18x7.5" are pretty darn light at 14 pounds ($399 each) but not as pretty as the GT1s 18x7.5" 17 pounds($329 each).
I have polished centerline RPMs in 17" which are doing pretty good. If you get them in 18" just don't get the chrome wheels as they are a bit heavier and more costly. Rough weight on the 18x7" are 16.6 pounds. About $399+ each. 42mm offset. For deals see-
http://www.centerlinewheels.com/wheel_deals_list.php
Waszak
Oct 21, 2017 05:55 PM
dpike
Sep 12, 2015 08:19 AM
Tires, Wheels & Brakes
Sep 9, 2015 11:08 AM
Ntety
Sep 2, 2015 08:39 PM
