FS:: 2007 MINI Cooper S w/ LSD - Mellow Yellow
SOLD - 2007 MINI Cooper S w/ LSD - Mellow Yellow $4900
Year: 2007
Model: Hardtop
Price: $4900
Mileage: 108646
Color: Mellow Yellow
Location (Region): Texas
- MINI Limited Slip LSD
- NEW EBC Redstuff Brakes
- Forge Intercooler
- Bilstein B14 Coil Overs (same as GP)
- H*Sport Rear Camber Links Upper and Lower set
- TSW 19mm Rear Sway Bar and NM Rear Sway Bar Links
- Mini Cooper Challenge Rear Exhaust - Cat Back
- RennTech Tune (+40hp/tq)
- JVC Radio, JBL Speakers, Kenwood powered sub
- JCW 17" Wheels
- NEW BFG g-Force Comp2 Tires (Light and sticky, no run flats!)
Maintenance
- All Service Campaigns Done over last 24 months -
- Chain Tensioner and Timing Chain
- High Pressure Fuel Pump (HPFP)
- Turbo Heat Shield and Aux Water Pump
- Water Pump
- Oil Filter Stand Gasket, Cat Gasket and Turbo Oil Lines
- Front Crankshaft Seal
- New Valve Cover and Seal
- New Clutch & Flywheel
- Upper Radiator Hose and Flush Cooling System
- Upper O2 Sensor
- NGK Plugs
- Windshield
- New Headlights
- Battery
Issues
- Airbag Light (Airbag module, ~$100)
- Seat Seam
Link to album: https://goo.gl/photos/6nVijDD8BQKAZV35A
LSD yo!
The limited slip is a very rare item. The transmission on this only has 54k on it! The axle came loose and took out the case; long story short, newer trans with LSD was installed. This car drives great with LSD, coil overs and sway bar.
