Chrome headlight washer cover loose
Old Oct 20, 2016 | 09:34 AM
geodav's Avatar
geodav
The cover does not fit tight against the headlight ring as it should. It is very loose and I'm afraid that eventually it will fall off. The opposite side is tight against the ring. Is there any way to tighten it up?
Old Oct 25, 2016 | 06:06 AM
It just clips in, its either the clips are snaped or the washer jet side tabs a cracked / broken.
https://www.northamericanmotoring.co...n-02-mini.html
