Clarifying a Wheel & Tire Setup
Old Oct 13, 2016 | 08:10 AM
drewstermalloy's Avatar
drewstermalloy
I want to make sure this wheel and tire setup will fit before I order anything. Has anyone run anything similar?
A friend of mine has a similar setup on his R53 but I wasn't sure if the clearances were any different.
I have an 09 MCS, stock suspension for now but it will be lowered in the spring. I don't mind using spacers if needed.
Wheels: 15x8 et36
Tires: R888 225/45/15
TIA
Old Oct 13, 2016 | 09:06 AM
3lusive's Avatar
3lusive
It might work but no guarantee...
https://www.northamericanmotoring.co...-cooper-s.html
The R56 S models accept a minimum of 16" wheels because of the brake size, at least that's what I thought. You'd probably need some sort of modification to get them to fit
Old Oct 14, 2016 | 04:12 AM
drewstermalloy
I've done a lot of searching on this forum, I know there are a few 15's that WILL fit, I just haven't seen anyone with the exact setup I want to run.
Old Oct 19, 2016 | 06:07 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Which 15x8 wheel are you considering?
The only way to get a 15x8" wheel to fit over the R56 front brake caliper is to find the right inner wheel dimensions for sufficient clearance (search and locate owners that have this setup) or use a front wheel spacer depending on the inner wheel dimensions and where the rubbing is.
Off hand I don't think it will work. It will work for an R53 with standard front brake calipers, not with JCW front brakes. For the R53 there will be some rubbing on the rear lower trailing arm so a thin 3mm wheel spacer will work for clearance. No spacer needed for the front to fit OK.
Old Oct 20, 2016 | 04:58 AM
gjxj's Avatar
gjxj
out of curiosity, can you downgrade the brakes if you are really keen on running smaller wheels?
Old Oct 21, 2016 | 07:22 AM
drewstermalloy
My fault, I forgot to list the wheels. They're 949 6ul's. I found a list of 15s that will work on the R56 and they were on there.
Old Nov 8, 2016 | 07:03 AM
drewstermalloy
Well I ordered the wheels, I guess we'll just have to wait and see if they fit
b6cool
Sep 2, 2016 03:30 PM
rob76turbo
Suspension
Sep 1, 2016 08:24 PM
1ZippyR53
Aug 26, 2016 09:41 AM
eforer
Aug 8, 2016 07:46 AM
Christian Hodges
R55 :: Clubman Talk (2008+)
Aug 6, 2016 05:31 PM
