15 Inch Stock Wheels, how wide can we go?
Old Oct 12, 2016 | 03:05 AM
Promius's Avatar
Promius
Hello everyone,
A friend of mine and his 2010 MINIJusta Hardtop need to get new tires. He saw my new A/S Comp2 on my 2013 MCS and loved them. But I got 205/55R16. I went a little wider and I love it. He loves it too.
For his Justa, stock tire is 175/65R15. How wide can he go on stock wheels/suspension? Would 195/55 be ok? He wants to get BFGoodridge Comp-2s like I did.
Any help with this is appreciated.
Thanks!
G
Old Oct 19, 2016 | 06:28 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For BFG Comp 2 Ultra High Performance Summer tire
195/55-15 will fit the OEM wheel but tire diameter is small at 23.4".
A small tire diameter will cause some error with odometer and speedometer. 888 vs 858 (OEM) revolutions per mile difference. Wheel gap will be about 1/2" more and ride height will drop 1/2".
In Ultra High Perf Summer tire class there is also-
Dunlop Direzza DZ102 treadwear 460
205/55-15 $82.57 each will fit rims 5.5"-7.5" wide so it is OK with OEM 15" wheel.
tire diam. is 23.9" which is closer to 24.4" OEM.
tirerack test result-
http://www.tirerack.com/tires/tests/...y.jsp?ttid=217
Vs the Comp-2 the DZ102 trailed and wasn't as good in wet but tire size is much better.
For a base Cooper on OEM suspension, 195 or 205mm wide tires are fine as long as tire diameter is about 24.4" or OEM.
tirerack owner results for UHP Summer tires-
http://www.tirerack.com/tires/survey...wdp=N&showcm=N
Another option is to search in another tire class like
Ultra High Performance All Season
I know you'll think the tread pattern isn't aggressive (and you're right)
Kumho Ecsta 4X II 205/55-15 $86.25 each, $60 rebate, 420 treadwear. good in dry or wet.
spearmin
Tires, Wheels, & Brakes
11
Oct 26, 2016 12:40 AM
mtxpert
R55 :: Clubman Talk (2008+)
Sep 30, 2016 03:40 PM
sbpwjm
Sep 22, 2016 08:08 AM
MrBlah
Sep 19, 2016 07:08 AM
Sigboi
Sep 17, 2016 04:03 PM
