Can't Get Coolant To Drain
Old Sep 30, 2016 | 10:11 AM
corliss hale's Avatar
corliss hale
Tried to change the coolant in my r56. Undid lower hose on left as most DIY instructions I could find recommend. About 3 qt. came out and that was it. Any suggestions what I should try next? If I gently pressurize the overflow I get a bubbling noise bu suggesting trapped coolant, but no significant flow.
I was hoping to get away without extreme measures like buying a Wetvac.
I'm leaning towards flushing it a couple of times with distilled water, putting the hose back and running the engine each time. But then I got to guess on how much antifreeze to use.
Old Sep 30, 2016 | 10:49 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
The wet vac method seems to be the best to get as much coolant out of the system when doing a flush. Lots of great info and steps with using that method in this NAM thread here: https://www.northamericanmotoring.co...ush-diy-3.html.
Make sure to use MINI blue coolant with 50/50 mixture of distilled water when refilling. We have wet vacs HERE if needed. Otherwise, maybe you can call a friend to see if they may have one. I have more than a few friends with one so you might get lucky.
Also, check out our coolant drain and fill article here: http://www.pelicanparts.com/techarti...ing_System.htm. Review the first comment below the article in the comments/suggestions area as an individual did give some info about how he was able to get more coolant out without a wet vac. Maybe it'll help a bit. Good luck!
888.280.7799 | 6am - 5pm PST
FranckB
Electrical
Nov 23, 2016 02:18 PM
ahurvitz
R55 :: Clubman Talk (2008+)
Oct 24, 2016 02:40 PM
taralini
Tires, Wheels, & Brakes
Oct 22, 2016 01:27 PM
Doc McCoy
Sep 28, 2016 06:24 PM
Jeff Proctor
Sep 28, 2016 01:15 PM
