Rattling Supercharger. Should I rebuild, replace?
Old Sep 23, 2016 | 11:57 AM
TraPofMinD's Avatar
TraPofMinD
I have an 04 Mini with a Cravenspeed 17% pulley and 140K miles. The supercharger started making some noise about 5K miles ago, and I couldn't find any problems that would cause it. Then it got louder, and I had a mechanic look at it, he said the bearings in the supercharger are shot.
I'm not a rich man, so my question is this: Should I risk a used unit, but a rebuilt one, or have mine rebuilt?
I'm in the central Ohio area; if that helps.
Old Sep 23, 2016 | 12:04 PM
IQRaceworks's Avatar
IQRaceworks
I would go with a complete rebuilt and tested unit.......but it all depends on how long you are going to keep the car, and what the price difference is on a used unit.
Old Sep 23, 2016 | 12:10 PM
ZippyNH's Avatar
ZippyNH
When you send "YOUR" unit away for a rebuilt, most shops measure parts, and replace them from Spares as needed.... reality is, you unit may not be the one you get back....it is a "core" unless it is a very small operation....and that can be risky...
Rebuilt units can be found from $600-1000....about 4-6 hours labor for a shop to swap it out...many places can order the rebuilt unit....so it is waiting for you to arrive....then your bad unit (if it still rotating, it's usually good as a core) is put back in the box and shipped out....
Old Sep 23, 2016 | 12:20 PM
TraPofMinD's Avatar
TraPofMinD
It starts to make less sense having my unit rebuilt if it's not significantly cheaper than buying another one. I'm reading a bit about the process of rebuilding, and it looks like it's out of my depth, and maybe out of my mechanics depth.
Old Sep 23, 2016 | 12:50 PM
ZippyNH's Avatar
ZippyNH
To rebuild one you really need a pile of parts to match clearances....
Your old unit is still worth about $500 as a core...
There are a few decent rebuilds, but Steigimer is well regarded quality wise, and not THAT much more than the cheap places that have a high failure rate (e-bay, ok warrenty, but most last a year or less).
To do it right, it takes skill, knowledge and parts....many have 2, but a good rebuilds have all 3.... steigimer is literally famous for other makes....and a SUSPECT they do a brisk bussiness doing units for many reputable vendors on this site....they just mark the units up another $300.
Old Sep 23, 2016 | 01:55 PM
BlwnAway's Avatar
BlwnAway
And unless things have changed, any unit you buy will still be a rebuilt unit, I don't think brand new have been around for a while.
So yes, if you're going to keep the car, spend a little extra for a quality job, esp if your not doing the work yourself (install) and would have to pay again if there were problems.
Don't forget, if your not doing the work and the shop doesn't supply and guarantee the S/C itself, if the replacement fails, any additional labor to redo things will be on you.
Old Sep 23, 2016 | 09:12 PM
TraPofMinD's Avatar
TraPofMinD
I had not heard that the failure rate was that high! I admit that I have been looking at options on eBay for about $700
Old Sep 24, 2016 | 04:34 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
first I've heard of that too, I thought it was the same shops selling on ebay
if it's the horn that's rattling cant you just replace it? used ones have dropped a lot in price too it's not a very hard job swapping them
Old Sep 24, 2016 | 11:44 AM
ZippyNH's Avatar
ZippyNH
For $200 more you can get one from steigimer....
There was a shop in "old town Florida" that is now using a different address..(eBay, and their own website)....had $500 unlimited mile rebuilds (was 3-4 years ago, bet they have gone up a bit) with a one year warranty...several folks went through 3 in a few MONTHS....(they were even a "vendor" for a couple months, but they were quickly dropped...and a couple places like WMW publicly stated the failure rates were so high, they stopped using them) they were changing the snount bearings but just glueing in new seals, no dissembling the waterpump PTO according to a couple folks....kinda of more a "lube" job with a couple parts than a rebuild....I'd run....it's about 4-6 hrs labor and about $100 in gaskets to do the swap if the units, plus shipping...so an extra $200 is not much imo for a QUALITY rebuild....
Me...I bought a spare early on off a wreck....never needed it...sold it for about what I had into t after having mine on the shelf for 3 years...about $600 for a 6000 mile unit...lol..when new were going for $1200-1500 from MINI.
Old Sep 24, 2016 | 02:14 PM
TraPofMinD's Avatar
TraPofMinD
My supercharger varies between just a noisy metal on metal sound to a rattling from what I believe is end float of the impellers. It needs more than a nose job.
I didn't really want to have my car down so long, it's a daily driver. I was hoping I could pick one up in Ohio somewhere.
Old Sep 24, 2016 | 02:53 PM
BlwnAway's Avatar
BlwnAway
You may just have to float the core charge and buy a rebuilt unit from a Mini vendor.
I think Chad usually has one in the shelf at DT, call and ask, shipping shouldn't be too bad to you, and the core back.
That's usually the only option for a quick swap.
Old Sep 26, 2016 | 07:58 PM
TraPofMinD's Avatar
TraPofMinD
I think you guys have swayed me to go with Stiegemeier. I called them today. Can anyone tell me that my Mini is gonna make more horsepower after? I mean, you can't, but you can, you know, just say it, like here's a chart that proves your worn out 140K blower was loosing X PSI (Probably) and now it's gonna be super, and chargy, and make X more horespowers!
Old Oct 13, 2016 | 03:41 PM
TraPofMinD's Avatar
TraPofMinD
My Supercharger is off and on it's way to Stiegemeier. Does anyone have a tensioner that they recommend?
Old Oct 13, 2016 | 06:13 PM
Shawnnn's Avatar
Shawnnn
https://www.amazon.com/ACDelco-38404.../dp/B001KSDZOY
Tensioner for you
Steigmeier did my sc too. Why not ask them your questions about hp gains? Id be curious to hear what they say.
Old Nov 22, 2016 | 04:22 AM
TraPofMinD's Avatar
TraPofMinD
I guess I forgot to update this post: I had Stiegemeier rebuild my supercharger and they did a great job. My butt dyno doesn't detect any horsepower increases, and the engine doesn't seem to rev any faster (These things spin up slowly!), but it doesn't sound like it's about to come apart now, so that's good. I couldn't be happier with this car!
Old Nov 22, 2016 | 04:56 AM
JAB 67's Avatar
JAB 67
Before you sent your old one away to be rebuilt (or exchanged) did you determine whether there was still oil in the pulley end and in the water pump end? Did Stiegemeier report back to you on what (if anything) they found upon disassembly?
Old Nov 29, 2016 | 03:37 PM
TraPofMinD's Avatar
TraPofMinD
There was about a shot's glass of oil, and metal shavings, in my supercharger. They didn't report anything, but a quick phone call will get you the owner who was happy to answer any questions you have.
Old Sep 13, 2018 | 03:14 AM
Poor Wood's Avatar
Poor Wood
03 supercharger pro failure
Okay I'm new here my friend passed away and left me a 2003 Mini Cooper S with 88,000 miles on it something like that well I got a weird rattle noise grinding sound from the supercharger it sounded like I got my car tore apart took the supercharger off found out that PTO and between the water pump and the sc is really f*** off the cuz yours between the I don't know the PTO in the supercharger itself will the plate and take off of the supercharger the gearing there is real sloppy I can move it back and forth maybe a an eighth of an inch true maybe a quarter of an inch play is it cheaper for me to buy a whole nother supercharger or try to replace the one I got I am very honestly poor I don't have much money at all and I'm trying to keep the car going cuz it is a good friend of mine's that is no longer with us and out of respect for him I'm trying to do it right and not just totally F the car off so any help any suggestions anyting would be very helpful thank you guys and hopefully good news upload pictures hopefully these help
Old Sep 13, 2018 | 03:34 AM
JAB 67's Avatar
JAB 67
May I suggest some punctuation?
Old Sep 13, 2018 | 03:38 AM
Poor Wood's Avatar
Poor Wood
That's it!?!? That's all u got to help my issue with the car?????
Old Sep 13, 2018 | 05:04 AM
Shawnnn's Avatar
Shawnnn
The cheapest option is to find a good used one.
Old Sep 13, 2018 | 05:29 AM
Poor Wood's Avatar
Poor Wood
Thank you.any suggestions?it would be greatly appreciated.
Old Sep 13, 2018 | 06:14 AM
Shawnnn's Avatar
Shawnnn
There are some on ebay for 400 but I haven't really looked all that hard. Check any local junk yards for possibly lower prices
Old Sep 13, 2018 | 06:41 AM
Poor Wood's Avatar
Poor Wood
Thank you very much Shawn for your time and input. I greatly appreciate it. Have a wonderful day.
Old Sep 13, 2018 | 06:57 AM
cavaliers60's Avatar
cavaliers60
local salvage yards would probably be your best bet as you can physically look at the supercharger and check for damage. You never know what the actual product you’ll get on eBay.
