New AIRLIFT *Bagged* Gen 2 MINI Kit & More.
Air Lift For Your Gen 2 MINI Cooper
No other suspension gives you the ability to comfortably drive you car daily, slam it to the ground for a show-winning stance, or tear up your favorite race track - all with the touch of a button.
Make no mistake - these are thoroughly performance-oriented kits. Handling dynamics are not compromised - simply dial in your ride to adjust the front and rear shocks.
Select your front and rear air ride kits then choose between 3H, 3P, V2, or Manual Paddle Valves Air Management Systems to complete the full system.
The MINI Gen 2 R56+ Air Lift kit allows for up to 4.1 inches
*4.1 inch drop on the front 4.9 inch drop on the rear.
Fits:
R56 MINI Cooper /S/JCW (2007-2013)
R55 MINI Clubman /S/JCW (2008+)
R57 MINI Cooper Convertible /S/JCW (2009+)
Click HERE
MINI F56/F55 Jack Pad Adapters & Schwaben Accessories
Take the danger and aggravation out of lifting your MINI with the ECS Tuning Jack Pad Adapter. Designed to fit the head of a standard floor jack, the adapter has a rectangular head that firmly engages the chassis jack pads. Positive engagement at jack head and chassis resists jack slippage and shifting, while the raised adapter head prevents damage to rocker panel trim and underbody panels.
Better safe than sorry
Fits:
F56 MINI Cooper /S/JCW (2014+)
F55 MINI Cooper /S/JCW (2014+)
Click HERE
MINI R60/R61 ECS Popular Trending Products
It all starts with the essentials - Do it right, or do it twice.
ECS Performance Essentials are a special blend of drivetrain and braking upgrades designed to fine tune and enhance the performance of your MINI.
The ECS Wheel Spacer Kits allow you to space out your wheels for a flush fitment. Improve pedal feel with Exact-Fit Stainless Steel Lines or enhance your overall wheel appears with new color matched wheel bolts.
Build it faster, build it stronger, build it with ECS
Fits:
R60 MINI Countryman /S/SX(ALL4)/JCW (2011+)
R61 MINI Paceman /S/SX(ALL4)/JCW (2013+)
Click HERE
Fits:
Click HERE
Fits:
Click HERE
Fits:
Click HERE
TJANK
Jul 31, 2019 06:23 AM
TJANK
Aug 10, 2016 11:46 AM
kmckmc
R55 :: Clubman Talk (2008+)
Aug 6, 2016 06:16 PM
