R50/53 passenger side wheelhop, torque solutions lower mount?!?
Old Sep 5, 2016 | 05:02 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Still chasing wheel hop, engine mounts are not leaking, lower is not cracked so I have not touched them.
Replaced/new
KW v3 coilovers
inner and outer ball joints
powerflex control arm bushings
so that leads me back to the engine mounts, does the "torque solutions" lower mount really fix wheelhop?
I get none from drivers side, only from passenger side I feel it autocrossing on tight corners and I can induce it anytime I want from a stop, just turn right and hammer it will result in instant wheelhop
Side note, even brand OEM control arm bushings are horrible, simply horrible now I can stop in a straight line on the track!
Old Sep 6, 2016 | 09:07 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Hm, I've always been told to fix that is to install stiffer bushings, which it looks like you did. I always found this as a really good description of wheel hop and what to do to fix it: http://www.mc2racing.com/tech/20061012a/. Maybe look into the PSRS system by Alta? I've heard good things in the MINI community. We sell the kit for $174.60 if you're interested after looking into it. It is in stock. Let me know.
Here is just a small excerpt about it:
PSRS Installed
Under braking after the ALTA PSRS is installed, the wheel will not move front to back period! Since there is no way for toe changes to occur, the steering feedback issues and wandering under braking all go away!
Under acceleration after the ALTA PSRS in installed, wheel hop disappears and the car will have far less tendency to follow the ruts in the road. In turn, the car will have more front end traction.
888.280.7799 | 6am - 5pm PST
Old Sep 6, 2016 | 05:09 PM
HaveATank's Avatar
HaveATank
I have the torque solutions Dog bone and never had wheel hop. Don't know if it the Dog bone. to be honest.
Old Sep 6, 2016 | 05:34 PM
bavmotors's Avatar
bavmotors
I've never had wheel hop and I'm using all oem style bushings and mounts. I've got the typical power mods, never experienced hopping just spinning.
Old Sep 6, 2016 | 06:04 PM
MrBlah's Avatar
MrBlah
I did not get any wheelhop on the track, but when I autocross I get it pretty bad, turn the wheel full to the right, punch it, wheelhop like mad
I wish the engine mounts were leaking/cracked, it would give me a reason to replace them, I might rig up a camera in the engine bay and video to see what is happening inside there
Old Sep 6, 2016 | 06:15 PM
bavmotors's Avatar
bavmotors
What condition are the transmission mounts in?
Old Sep 6, 2016 | 06:23 PM
MrBlah's Avatar
MrBlah
not sure it's not really visible without some disassembly, and it's on the "good" side of the car.
My JCW does not wheel hop, so it's gotta be something mechanical
Jonshungry
Suspension
Feb 26, 2017 09:35 AM
bneer
Mar 29, 2016 12:30 PM
JWA
Mar 21, 2016 07:49 AM
JWA
Mar 20, 2016 07:24 AM
PinkMiso
Mar 11, 2016 10:32 AM
