engine sounds like sewing machine
Old Sep 2, 2016 | 12:32 PM
Mtnmotor's Avatar
Mtnmotor
I have a 2006 r53 with 75000 mi... a friend recently said it is sounding like a sewing machine. kind of a whirring noise. I am pretty hard hearing and had not noticed it. it is defiantly engine and rpm related. Any ideas on what to look for? Supercharger belt is maybe 3 yrs old and 35,000 miles and don't see any signs of fraying. Thanks for any ideas!
Old Sep 2, 2016 | 01:02 PM
Chili_head's Avatar
Chili_head
Bushing in the alternator can make a whir (that becomes worse).
Old Sep 2, 2016 | 02:12 PM
Mtnmotor's Avatar
Mtnmotor
thanks, I will check the alternator. It has got worse as I can hear it now. I don't have a boost gauge but have not noticed any loss of performance.
Old Sep 2, 2016 | 02:35 PM
Capt_bj's Avatar
Capt_bj
is the oil up to level????
start simple .....
Old Sep 2, 2016 | 03:14 PM
Shawnnn's Avatar
Shawnnn
Or that's how it's supposed to sound.
Has your friend ever heard it before?
Old Sep 2, 2016 | 03:20 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Are you able to possibly post a video of it for us?
888.280.7799 | 6am - 5pm PST
Old Sep 2, 2016 | 07:10 PM
Mtnmotor's Avatar
Mtnmotor
Oil is up to level.. It is a new sound I am sure. I am most worried about possible supercharger issue. Can someone describe any warning sound before oil problem with supercharger? Or do belts start making more noise as they get more wear,I had a member put this one on right after I bought car. I am not sure about video, will look into. Thanks for response so far!
Old Sep 5, 2016 | 10:46 AM
jaiello's Avatar
jaiello
sewing machine sound
Replace timing chain tensioner its about 25 bucks. When these get stuck it makes a terrible racket. Mine was making that noise replaced it and it stopped
Old Sep 7, 2016 | 07:29 PM
Mtnmotor's Avatar
Mtnmotor
chain tensioner
I watched video of tensioner and that is not the problem. My problem becomes noticeable around 2500 rpm and is more of a whurr sound. I have the TSW engine mount and maybe something has came loose and is vibrating . I emptied the glove box and took everything out of interior but that didn't fix it. I haven't had a chance to get under car and check for something vibrating.
Old Sep 8, 2016 | 06:23 AM
Saltysalt's Avatar
Saltysalt
there might be a bolt loose somewhere in the engine bay causing a washer to bounce. if it was timing chain you would hear it all the time
Old Sep 8, 2016 | 06:32 AM
06supercooper's Avatar
06supercooper
Timing chain
Sounds like a timing chain issue. Check YouTube for videos there are a few and if the noises match up I bet that's your issue
Old Sep 8, 2016 | 09:28 AM
AoxoMoxoA's Avatar
AoxoMoxoA
I'm going to throw this out there and suggest the possibility that the "whirring" sound your friend noticed is the normal whirring/whining sound the supercharger makes when it kicks in upon revving the engine?
The reason you are now noticing it after never noticing it prior is possibly because you have been made aware of it?
Of course, taking a quick video with your phone and posting it here will go a long way towards diagnosing what it actually is, rather than all of us taking stabs in the dark...
Old Sep 8, 2016 | 10:16 AM
ZippyNH's Avatar
ZippyNH
Maybe somebody swapped your motor overnight with a Subaru motor?!
Jk....
But sudden changes are issues...
The SC can make a bit of a whirr....but have you done any changes? A airfilter change can make the sound louder, as can a pulley change, or other mods...
If there are no changes....
Get a "mechanic's stethoscope"...or a homemade equivalent....
And check the alternator and pullies, and maybe the sc itself....try to narrow down WHERE the sound is coming from.
Old Sep 8, 2016 | 01:02 PM
Mtnmotor's Avatar
Mtnmotor
I have a friend with a mechanic's stethoscope , that is a good idea. Thanks for all the suggestions.
arth4
Aug 9, 2016 10:02 AM
Mr. Krisztian
Apr 25, 2016 07:15 PM
jcrane82
Apr 16, 2016 07:45 PM
thelawson
Apr 13, 2016 11:04 AM
Rebeccaj75
Apr 9, 2016 07:54 PM
