R56 Cheap Turbo Fix?
Old Aug 29, 2016 | 07:31 AM
NB Cooper's Avatar
NB Cooper
Cheap Turbo Fix?
I was just rooting around and came across a replacement turbo "Core" from Rock Auto. This contains all the wear items with the exception of the by-pass valve in your exhaust housing. Just pull the cold side off and replace the core as opposed to spending four times this much on an overhaul. Slick!
http://www.rockauto.com/en/catalog/m...h%2Bkit%2C1993
Old Aug 29, 2016 | 07:48 AM
BigBoost's Avatar
BigBoost
hmm? yeh i would stay away from it!
Old Aug 29, 2016 | 08:00 AM
NB Cooper's Avatar
NB Cooper
What's your reasoning?
Old Aug 29, 2016 | 01:12 PM
oldbrokenwind's Avatar
oldbrokenwind
I'm going thru a repair / replace decision process with an aftermarket turbo. Changing only the center section is more economical, but we have options there too --- new vs rebuilt. New from the original mfgr would be the preferred choice for longevity, but it's more expensive. New from someone else is risky. Rebuilt is also risky, as this is a hi-stress part --- material fatigue, who does the rebuilding and where did the parts come from, etc. Gotta do your research, or gamble.
It's not quite as simple as "Just pull the cold side off and replace the core ---". This center section (CHRA) has to be removed from both ends. Mine has a huge (3 - 4" ID) snap ring that I don't have a tool for. Then the CHRA has fragile "blades" on both ends --- needs TLC when handling. And the rebuild people recommend new units 'cause the re-builts aren't reliable.
CHRA's seem to be worth what you pay for them. Again, do your research!
Old Aug 30, 2016 | 01:29 PM
MazMini's Avatar
MazMini
http://gpopshop.com/services/
These guys do K03 rebuilds and can even upgrade the internals all for less than $600.00
jstines
R60/R61 Stock Problems/Issues
20
Apr 19, 2022 07:53 AM
Ppeterso2
Mar 31, 2016 06:01 AM
kryall
Mar 21, 2016 08:51 AM
NYTransplant
Mar 13, 2016 11:10 AM
Juane
Jul 17, 2002 01:43 PM
