R50/53 Alternator question for swap
Old Aug 25, 2016 | 07:20 AM
slo_crx1's Avatar
slo_crx1
Can anyone confirm or deny a question regarding r50 and r53 alternator interchangeability for me?
Long story short, I'm in process of gathering parts for a turbo conversion. One of the affected parts is the alternator. I have been told that the r53 alternator can be mounted to the r50 location with slight modification, but that the pulley is a different size and would have to be changed to the r50 version. Apparently the electrical plugs are different between r50 and r53 models as well, which is what prohibits using a standard r50 alternator for the swap...any truth to this as well?
I'd hate to buy another alternator and find out it's the same general part just with a different pulley.
Thanks guys!
Old Aug 26, 2016 | 06:52 AM
nkfry's Avatar
nkfry
The alternators themselves are different, both in size and in amperage.
If you're looking for the best information on a turbo swap you should find Chase Gamblin, sorry don't have his username, but he's got a bad turbo car...
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Aug 27, 2016 | 11:55 AM
slo_crx1's Avatar
slo_crx1
Hmm, that presents a problem then. The other problem I've found will be the wiring...the r53 uses a 3 pin connector, whereas the r50 only uses a two pin plug. I'll have to look up Chase Gamblin then and pick his brain. Thank you!
R53Goodness
Apr 4, 2016 11:11 AM
Scrodes
Mar 31, 2016 07:18 PM
AlphaQuad
Mar 29, 2016 07:07 PM
JWA
Mar 20, 2016 06:40 AM
KinetechMW
Mar 19, 2016 05:52 PM
