R50/53 Wheel question??
Old Aug 23, 2016 | 02:53 PM
jaiello's Avatar
jaiello
Wheel question??
I have a 2006 Mini Cooper s r53 with factory 17. I have a chance to purchase some really nice wheels but I can't get a clear answer if they will fit. They are 4x100 17x7 -35 offset. I know the size is fine but the offset is what I can't get a clear answer. The guy who has them seems to think they won't fit. Any help is appreciate.
Old Aug 23, 2016 | 03:04 PM
cristo's Avatar
cristo
Alliance Member
If I'm reading that correctly as negative 35 mm offset, they really won't work.
They will stick way out.
Offsets of about +35 to +50 will work with 205/45/17 tires and 17x17 wheels.
Old Aug 23, 2016 | 03:08 PM
jaiello's Avatar
jaiello
Wheel question
Thanks for the reply that's what the seller said but I was making sure
Old Aug 23, 2016 | 03:16 PM
Mini Mania's Avatar
Wheels
Hi jaiello:
Here's an application guide that shows which wheels fit which models. Hope this helps!
http://new.minimania.com/Mini_Cooper...lication_Guide
Old Aug 25, 2016 | 08:34 AM
slo_crx1's Avatar
slo_crx1
Are you sure you aren't confused and mean a +35 offset? +35 offset will fit just fine, I fit +20 under mine (barely) but +35 will only be a slight offset from the factory wheels.
Old Aug 25, 2016 | 03:25 PM
jaiello's Avatar
jaiello
Wheel offset
The seller posted -35 offset I will ask again I thought the same thing.
boydie
Mar 3, 2019 10:20 AM
jpwins
May 17, 2016 10:03 AM
moremini
Apr 20, 2016 07:08 AM
jcrane82
Apr 16, 2016 07:45 PM
JWA
Mar 20, 2016 04:29 PM
