R50/53 Need help with tachometer height
Old Aug 17, 2016 | 08:27 PM
FranckB's Avatar
FranckB
Hi guys ! my '02 S is equipped with a quick release connected to a MOMO steering wheel (really small compared to OEM ) and now i can't see the tach correctly. Is there a way to get it to sit higher? every way i tried to position my self, the steering wheel or my seat there is alway a critical part of it i can't see.
Old Aug 18, 2016 | 12:19 AM
rkw's Avatar
rkw
Remove the two Torx screws that secure the tach to the steering column. Slide the tach out of its bracket. At this point, you will have an unmounted tach, but still attached to its wiring harness. I think there is enough slack in the wiring harness that you can fabricate a bracket to make the tach to sit higher.
Old Aug 18, 2016 | 02:45 PM
FranckB's Avatar
FranckB
thanks for the answer ! it did help a lot..after removing the tach i went and decided to get longer screws and put some washers in between the speedo legs and the mounting bracket. It sits higher while still keeping the factory mounting point
sam.k
Jul 15, 2016 06:11 AM
2001f4s
Apr 29, 2016 05:42 AM
saturn5rocket
Apr 7, 2016 02:09 AM
R53Warrior
Apr 3, 2016 08:35 AM
PinkMiso
Mar 11, 2016 10:32 AM
