R50/53 Help with engine misfire codes Please!
Old Jul 27, 2016 | 03:11 PM
joe29's Avatar
joe29
2003 MCS with 115k miles
A month ago my SES light came on and produced a P0302 code. I promptly changed the coil, plugs and wires and reset the SES light. I've since put on about 500-600 miles without any problems. Last night, the DSC and SES lights come on and engine running rough with lots of hesitation. Pulled over, turned the motor off. Restarted after about 5 mins and it ran like normal. The DSC light went away but the SES light remained. I read the codes and now have a P0304.
I read some old posts about similar symptoms but the OPs didn't state the outcomes.
Any idea how I should proceed? I'm fairly handy but not a mechanic by any means.
Thanks!
Old Jul 28, 2016 | 07:03 AM
nkfry's Avatar
nkfry
What plugs did you put in? What are they gapped to? Did you goober everything with dielectric grease? If so, wipe it off.
Compression test? Timing? Fuel pressure?
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Jul 28, 2016 | 12:58 PM
Mini Mania's Avatar
Misfire
Thanks!
Since that is the Cylinder 4 misfire code I would definitely check the plugs, wires and compression. Vacuum leak a possibility. I assume you are using premium gas. Worse case scenario would be a burnt exhaust valve but I wouldn't be concerned about that until the other variables are eliminated.
Old Jul 28, 2016 | 02:15 PM
joe29's Avatar
joe29
Thanks for the replies so far.
I put in NGK-BKR6EGP from my local parts store and gapped them to 0.032. I didn't use any dielectric grease. Also, yes, premium gas 91 octane.
I'm going to pick up a loaner compression tester today.
Also, how do I check for a vacuum leak?
I'll report back the compression numbers once I have them.
Thanks.
mikeyr
Classic Mini Talk
Apr 26, 2016 02:12 PM
Lewis Lee-Martin Williams
Mar 14, 2016 07:36 AM
ochichernie
Aug 23, 2002 01:33 AM
minifinn
Aug 14, 2002 06:42 PM
SpeedyMCS
Aug 12, 2002 12:26 PM
