FS:: Alta filer with silicon tubing for GEN2
Old Jul 11, 2016 | 11:55 PM
sukonthorn's Avatar
sukonthorn
Price: $149
Location (Region): SoCal
Up for sale is used Alta filter with silicon tubing
ALTA Performance has once again set the bar very high for the competition! The ALTA Turbo MINI Cold Air Intake not only adds a proven 10WHP and 10ft-lbs of torque to your 2007+ MINI Cooper Turbo S and JCW, but it also unlocks the sound from your turbo! With this intake not only will you hear the turbo sucking in and compressing the air, but you will hear the OEM blow off valve blowing open.
SOUND: With an ALTA intake system your car will make a throaty, deep tone on throttle that is undeniably modified. You will be able to hear your turbo spooling and hear your blow off valve every time it opens. Even the stock one.
HIGH FLOW FOAM FILTER: Included with all ALTA intakes is our high flow foam filter. ALTA Performance filters feature a unique two piece design allowing the user to remove the foam filter element for easy cleaning. Easily run the element under a faucet for cleaning and ring out by hand. Simply slip the foam sleeve back over the filter frame and your ready to go. Many ask us why not a "K&N Style" filter? The quick answer is foam flows much better when dirty.
NO CHECK ENGINE LIGHTS: When dealing with MAF (Mass Air Flow) sensors, small changes in the intake system can create turbulence. While this may seem insignificant, it can make huge changes to how the car runs. Because we are familiar with this problem, great care was taken to eliminate any turbulence issues that might throw a CEL, or make the car run too lean or rich. What does that mean to you? An increase in performance, proper fuel economy and protection for your engine. ALTA is the only manufacture that takes this concern so seriously and our customers reap the benefits!
Gen2 MINI:
R55-S MINI Cooper S Clubman: 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015
R56-S MINI Cooper S Hatchback: 2007, 2008, 2009, 2010, 2011, 2012, 2013
R57-S MINI Cooper S Convertible: 2009, 2010, 2011, 2012, 2013, 2014, 2015
R58-S MINI Cooper S Coupe: 2011, 2012, 2013, 2014, 2015
R59-S MINI Cooper S Roadster: 2012, 2013, 2014, 2015
R60-S MINI Cooper S Countryman: 2011, 2012, 2013, 2014, 2015, 2016
R61-S MINI Cooper S Paceman: 2013, 2014, 2015, 2016
Attached Thumbnails Alta filer with silicon tubing for GEN2-cimg1691.jpg   Alta filer with silicon tubing for GEN2-cimg1692.jpg   Alta filer with silicon tubing for GEN2-cimg1693.jpg
