R50/53 driver window glass isssues
Old Jun 26, 2016 | 08:18 PM
zukin's Avatar
zukin
my 2005 mini cooper driver window does not travel all way up when door is closed so it whistles at highway speeds. can this be adjusted?
has anyone else had the same issue?
Old Jun 26, 2016 | 10:32 PM
808R53's Avatar
808R53
My Cooper S was like yours wouldn't roll all the way up there was like 2" left so I would just pull the rest up by hands. Went to a auto glass shop they told me my window regulator was going. Went to the dealership, they wanted like $375 fk that so went to Rock auto and got it for $130 + $30 shipping to Hawaii, went back to the glass shop they charge me $100 labor and now it's all good
Old Jun 26, 2016 | 11:23 PM
ItsmeWayne's Avatar
ItsmeWayne
Hi Zukin,
The window has up adjustments (on regulator, which requires door panel off) and pitch adjustments (on bottom of door). The first adjustment may require the special tool to adjust it. (I bought one, but I can tell you it can be done without it.) The pitch adjustments are under the door. These are two 10mm bolts. You can loosen them, push the bolts up and push to the outside of car and that adjusts the window to tilt in further in and tighten the glass to the door seal. (fairly easy adjustment)
Hope this helps, Itsme Wayne
Old Jul 1, 2016 | 06:25 PM
BUGETER's Avatar
BUGETER
Go to this site, www.pelicanparts.com They have the entire procedure to replace the window regulator and adjustment. I bought the regulator for $50 about 4 years ago and did the work myself in my front yard.
rondelli
Jul 16, 2016 04:33 PM
Mar 24, 2016 11:31 AM
steebo777
Mar 21, 2016 06:33 AM
JWA
Mar 20, 2016 04:29 PM
normstangl
Aug 23, 2007 02:24 PM
