R50/53 Just what does it do?
Old May 9, 2016 | 04:56 AM
98oilhead's Avatar
98oilhead
'03 r 53. Just what does the "controller" for H.I.D headlights do?
I'm having a problem with the left headlight "stepper" motor which changes the height adjustment...It won't "step".Am I assuming too much that the "controller" is separate from the "ballast"?
Old May 9, 2016 | 05:34 AM
Saltysalt's Avatar
Saltysalt
not sure what the controller is, that could do the height adjustment. the ballast is for powering the bulbs. since I don't have a controller and I did a HID retrofit.... id assume the controller is as so
Old May 9, 2016 | 09:38 AM
iamfarha's Avatar
iamfarha
Don't know that's it's called a 'controller' per say, but I know the leveling sensors are down on the control arms near the crash tubes. They're made out of cheap plastic, perfect for disintegrating after a run in with a pothole...worth a look see!
Old May 9, 2016 | 09:40 AM
iamfarha's Avatar
iamfarha
yep, lookie here: http://www.realoem.com/bmw/enUS/show...diagId=31_0623
Old May 9, 2016 | 11:02 AM
That controls the aim of both the front head lights.
https://www.northamericanmotoring.co...hen-right.html
Sounds like the headlight mount inside arm might have popped out or broke. Its inside the housing itself.
https://www.northamericanmotoring.co...turned-on.html
cerenkov
May 11, 2016 04:09 AM
ojannen
May 10, 2016 12:03 AM
Dave Elliott
May 8, 2016 06:04 PM
andyroo
May 7, 2016 02:12 PM
WayMotorWorks
May 4, 2016 09:01 PM
