R56 Question about problems my mini may have.
Old Mar 24, 2016 | 12:54 PM
SqAAAWWW's Avatar
SqAAAWWW
I just purchased a used 2011 Mini Cooper S R56 with 65k and according to the car fax the timing chain was never replaced. When I start-it it makes a ticking noise. I wasn't sure if i was effected by the Timing chain problem, i believe it has the N18 engine since it has a cover over the spark plug wires and spark plugs (they are not visible), Worried since i just purchased it. Also it does need an oil change soon according to the Minis computer.
Old Mar 24, 2016 | 02:17 PM
Its the injectors that make the ticking noise , on the n18 the timing chain is not so much an issue as it is on the early n14 engines. Do you have a video. Do the oil change at 5000 - 7500 miles and you will be fine. Which is early compared to the computer which might be set at 10K or 15K.
Oil kits here : For the oil go with the LL-01 recommended above or the ones we have in our oil service kits, they are also LL-01 . The Porsche stock mobile 1 is also the same for MINI.
https://www.ecstuning.com/Mini-2011-Cooper-R56-S-Coupe-L4_1.6L_N18B16A/Engine/Oil_Service/
https://www.ecstuning.com/Mini-2008-Cooper-R56-S-Coupe-L4_1.6L_N14B16A/Engine/Filter/
Old Mar 25, 2016 | 04:24 AM
AFN704's Avatar
AFN704
Isn't the oil supposed to be 5w-30?
Old Mar 25, 2016 | 05:10 AM
The MINI oil is the weight , but the other listed also meet the LL-01 , MINI recommends the 0w-40 mobile 1 euro also as an optional oil.
AxL_Z
Mar 30, 2016 01:45 PM
jmcveyster
Mar 6, 2016 08:25 PM
Jake Lee
Mar 1, 2016 06:24 PM
Accessory Products
Feb 21, 2016 07:23 PM
Feb 16, 2016 11:07 AM
