wheels?
Old Aug 26, 2004 | 02:41 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
wheels?
heres a pic of wat my mini looks like i would like a nice wheel for under 150$ i would also like to keep the stock run flats any suggestions, please post pics if ya want.
Old Aug 26, 2004 | 03:31 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Lots of choices
Aloha and welcome to NAM.
For aftermarket wheels stick to 17x7 or 17x7.5" 4x100 bolt pattern with wheel offset of about +42mm to +48mm. This will allow you to lower your MINI later and still use the wheels without rubbing the inside of the wheel wells. If you choose wheel offset of +37mm to +48mm then stick with the stock suspension to avoid rubbing.
Your stock runflat tires will fit on the above mentioned 17" rims.
You may shop at tirerack.com for a very good selection of wheels in 17"
Your upgrade garage!
See-
ASA rims- JS 1/JS 5/JS 6
ASA EM9 17x7 offset +40mm 21 pounds $139 per rim
Bright satin silver paint finish
Kazera KZ-R 17x7 offset +45mm 19.6 lbs. $129 each rim
Kazera KZ-S 17x7 offset +45mm 18.5 lbs. $129 each rim
Also Kazera KZ-T and KZ-U (18.5 pounds) for $129 each rim
Sport Edition Fox 2/Sport and TK5 rims
Sport Edition Fox 2- 17x7 +40mm 22.5 lbs. $144 each rim
Sport Edition TK5- 17x7 +45mm 22 lbs. $139 each rim
Kosei K1 racing are good but a bit more at $179 each.
Or at edgeracing.com - see
http://edgeracing.com/2004/Mini/Cooper_(all)/wheels/17/
In your price range consider-
Flik wasp black 17x7 offset +42mm 19 pounds each $102 per rim
Flik wasp anthracite 17x7 offset +42mm 19 pounds each $102 per rim
Flik artic anthracite 17x7 offset +42mm 18 pounds each $102 per rim
Flik lex 17x7 offset +42mm 17.5 pounds each $122 per rim
5zigen typhoon gun metal 17x7.5 offset +42mm 20 pounds $140 per rim
Flik Tdr-b (Team Dynamics Black)17x7 offset +38mm 15.5lbs. $155 per wheel
(lots more choices not shown)
There are some nice rims in the $200 each range as well.
Weights will vary- the stock 17" S-lyte rims are 25.1 pounds each so any rim that is about 18-20 pounds will be an improvement. The lightest 17" rims will run from a little over 12 to about 15 pounds each.
Last edited by Alex@tirerack; Aug 27, 2004 at 08:24 AM. Reason: added tracking inforation, giving NAM more click thru credit!
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Tires, Wheels & Brakes
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
