Tires, Wheels & Brakes
:: ECS Tuning :: ECS Geomets Rotors | TPMS Sensor (Free ship) | Gen European MINI
Old Feb 22, 2016 | 02:16 PM
ECS Tuning
Gen 1 MINI
ECS GEOMET® Coated Brake Rotors R50 R52 R53 MINI Cooper
ECS Tuning proudly introduces our line of premium, corrosion-resistant rotors: GEOMET®.
GEOMET® is a special coating containing metal oxides, zinc, and aluminum flakes, sprayed over the entire rotor surface to ensure complete coverage, and baked on at 600 degrees to form a durable and attractive silver-gray finish that fights rust far better than paints or other conventional coatings.
You can expect your new GEOMET® rotors to outperform and outlast stock rotors, and look great behind your alloy wheels.
Fitment:
R50 MINI Cooper (3/2003-7/2006)
R52 MINI Cooper Convertible /S/JCW (2005-7/2006)
R53 MINI Cooper S/JCW (3/2003-7/2006)
Click HERE For MINI Options
Fitment:
R50 MINI Cooper (7/2006+)
R52 MINI Cooper Convertible /S/JCW (7/2006+)
R53 MINI Cooper S/JCW (7/2006+)
Tire Pressure Monitor Sensors | MINI Gen 2
Tire pressure monitoring is a convenient feature - when it's working properly.
Too often, when the tire pressure light illuminates in your BMW, the cause has nothing to do with the pressure inside your tire.
A worn tire pressure sensor is usually the culprit, sending false readings to the
ECU, causing unnecessary concern to the driver.
ECS offers replacements sold individually or as a set of four. After installation, simply navigate to the TPM screen to clear the light from your dash.
Under Pressured?
Fits:
R56 MINI Cooper /S/JCW (7/2008+)
R55 MINI Cooper Clubman /S/JCW (7/2008+)
R57 MINI Cooper /S/JCW (2009+)
Fitment:
R58 MINI Coupe' /S/JCW (2012+)
R59 MINI Roadster /S/JCW (2012+)
Fitment:
R60 MINI Countryman /S/SX(All4)/JCW (2011+)
R61 MINI Paceman /S/SX(All4)/JCW (2013+))
Gen 1 MINI
MINI Euro Cubby Tray | MINI R50 R52 R53
This snap-in storage cubby tray is a fast and easy way to add extra storage for small items to your MINI R50 R52 R53.
Straight from the Euro market, the unit comes in panther black to match the original dash panels. The grippy rubber tray liner helps keep small items from sliding around.
A spare rectangular hole in the panel accepts a stock switch so you can control any accessory you choose. Or, cover the hole with the blind plate included in the kit for a smooth appearance. Add even more storage room with the Euro Parcel Shelf.
Cubby Buddy
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE For Gen 1 MINI Options
Old May 25, 2016 | 10:09 AM
Back in stock.
Old Jun 3, 2016 | 06:41 PM
TonyB's Avatar
TonyB
ECS Tuning
Gen 1 MINI
Fitment:
Fitment:
Under Pressured?
Fits:
Fitment:
Fitment:
Gen 1 MINI
Cubby Buddy
Fits:
Swapping the trailing arms on my Sep 2002 build now, with alloy ones (GP), just cleaned-up one of the rotors, and while it looks fine, I suppose it might be a good time to put in new ones, in the rear... Seems that the above are for build dates after mine though.
I have Wilwood Race ones in the front (11.75” GT slotted rotors, 4-piston DynaPro calipers). If you have any recommendations for the rear, do share. checking-out your website now....
Alpha Motoring
Jun 7, 2016 12:52 PM
Jan 18, 2016 10:38 AM
molala
Jan 17, 2016 11:24 PM
ti22fjc
Jan 15, 2016 07:39 AM
Suspension Products
Jan 13, 2016 12:31 PM
