B F Goodrich g-Force Rival question
Old Feb 21, 2016 | 12:38 PM
JAB 67's Avatar
JAB 67
I have a set of B F Goodrich g-Force Rivals, 215/45ZR17-91W. Two have lots of tread life left; the other two probably won't pass inspection. It appears that this tire is no longer available from B F Goodrich, but have been replaced by them with several 'look-alikes.' Can someone suggest what would be an acceptable substitute if I'm only buying 2? TIA.
Old Feb 21, 2016 | 02:04 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
If you want to match the Extreme Summer Rival tires then-
see
http://www.tirerack.com/tires/tires....Z2SS&tab=Specs
Dunlop Direzza II star spec $144.20 each at tirerack, call Alex at ext 4294 to order two and put them on the rears.
Or
http://www.tirerack.com/tires/tires....1RXL&tab=Specs
$124.20 each, very grippy tire in dry or wet.
You wore out two tires because they were left on the fronts which are used more heavily when turning braking and accelerating. Rotating tires every 4000 miles helps to allow tires to wear more evenly. Keep tire pressures up too for best life and performance.
Another option is to go with a Max Summer tire of which there are many choices in 215/45-17. In general compared to the BFG Rivals, Max Summer tires will wear longer and be more comfortable with less tire noise but the rubber is not quite as grippy.
example Max Summer tire
http://www.tirerack.com/tires/tires....PPXL&tab=Specs
$110.20 each
USA-RET
Feb 27, 2016 07:47 PM
CamPorta
23
Feb 24, 2016 08:21 AM
SomeguyinAZ
Tires, Wheels, & Brakes
Feb 21, 2016 07:02 AM
d00lindalton
Feb 20, 2016 12:54 PM
