Tires, Wheels & Brakes
Mini Cooper Wheel Spacer 12mm Pair 5x112 W/silver Bolts
Old Jan 6, 2016 | 10:13 AM
Mini Mania's Avatar
Mini Cooper Wheel Spacer 5mm Pair 5x112 W/silver Bolts
Mini Cooper Wheel Spacer 15mm Pair 5x112 W/silver Bolts
Mini Cooper Wheel Spacer 20mm Pair 5x112 W/silver Bolts
2014+ F56 Mini Cooper and Cooper S Hardtop
2015+ F55 Mini Cooper and Cooper S Hardtop 4-Door
2016+ F54 Mini Cooper and Cooper S Clubman
2016+ F57 Mini Cooper and Cooper S Convertible
Use Wheel Spacers provided for MINI to change the handling dynamics, or simply to move your wheels out for appearance. Includes two spacers (1 pair) and 10 bolts (with appropriate length to match the spacer width). Bolts are available Silver or Black. Fits the following models:
Available in 5mm, 12mm, 15mm, and 20mm Thickness. Sold in pairs with 10 bolts (Black or Silver).
Why Spacers?
When all-out cornering performance is your objective, the basic rule of physics applies: WIDER is better. These high quality hub-centric wheel spacers let you balance the handling and performance of your MINI - and several to suit a more aggressive driving style without spending the time, money and trouble for bigger wheels and tires.
These wheel spacers begin with a select piece of 6063-T6 aluminum, which is drop forged , increasing the materials molecular density, for added strength. Then only after careful inspection the rough formed blanks are C.N.C. machined to within .0005 tolerance of there final fitment. Each component is then heat treated for stress relief, and anodized for superior corrosion protection.
Conventional flat spacers (extended bolts included): These fit between your wheel and bearing hub secured by a longer version of the factory wheel bolt. Which is included with the kit. This is the perfect choice if you do not intend to convert to wheel studs, and your current wheels are designed for use with the factory wheel bolts.
Wheel spacers thicker than 12mm are machined to include the protruding hub centering rings which will always center your wheel for proper wheel balance.
Lug Bolts torque:
2014+ Hatchback (F56): 101 ft lbs.
2015+ Hatchback 4-Door (F55): 101 ft lbs.
Tighten the lug bolts in a diagonal pattern.
Important notice:
Acidic wheel cleaners will damage surface coatings! Follow the directions for use and the warnings found on the label of the cleaner precisely.
NOTE: Due to liability issues, lug bolts cannot be returned. Please make sure you have the proper application before purchasing. If you have any questions please email us and we will do our best to help.
JamesDeBart
Feb 10, 2016 07:13 AM
autoxgod
Nov 30, 2015 06:42 AM
MINI-Madness
Nov 27, 2015 05:27 PM
PelicanParts.com
Nov 25, 2015 02:00 PM
PelicanParts.com
Car Care Products
Nov 25, 2015 01:59 PM
