Mini Cooper Coilovers Bilstein B16 Pss10 Gen3 F55 F56
Old Dec 31, 2015 | 11:18 AM
Mini Mania's Avatar
Part No: G3NMS3064
SALE Price $2095.00
Was: $2,715.79
You save: $620.79
This is Special Order Only Item
Fits the following models:
2013+ F56 MINI Cooper and Cooper S Hardtop
2014+ F55 MINI Cooper and Cooper S Hardtop 4-Door
NOTE: Not compatible with the factory Adaptive Damper option.
The BILSTEIN B16 PSS10 KIT is the ultimate race inspired suspension system, delivering unsurpassed driving performance in any situation. This kit puts you in complete control, providing the kind of precise suspension tuning formerly available only on race cars. From a weekend of competition to daily driving, this system provides perfect handling performance for every situation. The manually adjustable damping mono-tube gas shock absorbers feature 10-stage precise compression and rebound settings, from comfort to competition. Bilstein utilizes debris resistant round threads on these dampers to ensure spring adjustment remains effortless throughout the life of the kit. The surface is coated with Triple-C-Technology coating to ensure long lasting resistance to corrosion and flashy good looks.
Features and Benefits:
  • Individual settings ranging from maximum Comfort to aggressive Sport can be selected by the twist of a dial (10 on PSS10)
  • Rebound and compression phases can be selected in parallel via the adjusters with the unit in situ
  • Threaded body adjustable range of 20 mm at both axles
  • Lowering of approx. 30-50 mm at front and rear
  • Road-tested and fine-tuned by BILSTEIN ride engineers, under extreme motorsports conditions
  • Spring plates and lock nuts made from a special aluminum alloy
  • Surface coating using Triple-C-Technology®for long-lasting corrosion resistance
  • Round threads for easy adjustment
  • Quality sport springs made from highly durable material
  • Gas pressure technology
  • BILSTEIN monotube / Upside-Down technology, made in Germany
Eurothrasher
Jul 11, 2019 03:30 PM
Flipper & Punkin
MINI Camera and Video
30
Apr 2, 2017 08:57 AM
JamesDeBart
Feb 1, 2017 12:47 PM
MINIdame
Jan 10, 2016 02:15 PM
y8s
R60/R61 Stock Problems/Issues
Dec 3, 2015 06:05 AM
