Suspension Wheel Gap Uneven after New Tires?
Old Dec 22, 2015 | 11:21 AM
MothAudio's Avatar
MothAudio
After install of four (4) new Michelin 205 / 50 / 16 tires on my '09 Clubman the wheel gap is uneven. While I didn't measure the gap with the OEM run flats to the naked eye it's a noticeable difference between driver/passenger side. On even ground it's approx. 1/2" but on my gravel driveway it's like 2". I didn't inspect the car after they put the new tires, just noticed it a couple of weeks later [like I said the gap varies depending on surface]. I also installed 10mm spacers after the fact. Performance/ride seem unaffected, it's a cosmetic issue. I understand there can a be a settling period but it should have settled by now. Any ideas? TIA.
Old Dec 22, 2015 | 11:29 AM
nkfry's Avatar
nkfry
The gap is going to be different front to rear, just putting tires on won't affect anything. What prompted you to measure the gap?
Why did you install spacers?
Do you have spacers on all 4 wheels? If not than that would explain a difference in gap.
Parking on inclines will change gap, parking on imperfect ground will change gap.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Dec 22, 2015 | 11:37 AM
MothAudio's Avatar
MothAudio
I should have clarified, the difference is not front/back but driver/passenger side. Yes, spacers all-around.
To clarify I'm referring to the gap between the top of the tire and the bottom of the wheel well trim.
May 25, 2016 10:23 AM
GimmeBoost
Nov 12, 2015 11:19 AM
eddyjoe
Nov 10, 2015 06:53 AM
KG-CMF
R55 :: Clubman Talk (2008+)
Oct 28, 2015 01:35 PM
BMWNTHZST
Oct 28, 2015 04:56 AM
