R58 What might I expect next?
Old Nov 10, 2015 | 10:46 PM
twriter's Avatar
twriter
My base Coupe recently passed through 83K miles. In the past few months, I've put around $2500 in unexpected maintenance/repairs.
In June, I got a yellow engine light and rough idling--on a Friday night after work, no less. Turned out I needed new spark plugs, and the replaced the coils too. $500. Was also down around 3 quarts of oil.
In August, got a maintenance light. Dealer diagnosed it as brakes, but a local MINI specialty shop found no issues with brakes, but a water cooler leak. Replaced the stock plastic(!) with a metal one, replaced a worn belt, replaced the cabin filter. $1500. (Was also told how much oil MINIs can eat.)
In August, got a yellow engine light, rough idling, on a trip to Vegas. Brought it to the MINI dealer. Turns out I'm pretty much an idiot. Had tried topping off with a quart before I left for the drive and failed to seat the oil cap correctly. That cost me a new set of spark plugs to replace the new ones from 2 months earlier. $200+
Couple of weeks ago, left work (late as usual), car wouldn't start. Called AAA, dead battery. Got a jump, drove it home, same issue in the morning. Got a jump from AAA, took it to my mechanic, got a new, higher-capacity battery. $200.
I have tires that have somewhere around 30-40K on them, but they are quality low rolling resistance tires (that I saw no increase in gas mileage with) with a 70K warranty and I still see plenty of tread. Brakes, AFAIK, are all good, although the front brakes have been lasting only around 35-40K miles.
But what I want to know is, at this point, after almost 3 1/2 years and this many miles, are there big-ticket items that I'm likely to face in, say, the next 6 months to a year that I might likely expect or should be keeping my eye out for? (And budgeting for.)
Old Nov 11, 2015 | 02:26 PM
Water pump, thermostat housing, water pipe. Those are the major ones. For a Cooper not too may valve cover PCV issues. Not too many timing chain issues either with the N16 engine. Sounds like maintenance and tires, that's about it.
Post up some pics.
Old Nov 11, 2015 | 04:43 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I think you need to find new Indy mechanic. Overflow tank, belt and cabin filter for $1500 seems way high, sure that was all they did? Some independent shops have learned they can charge dealer prices and get away with it.
Old Nov 12, 2015 | 10:27 PM
twriter's Avatar
twriter
I should have said that the water pump was leaking, and that's what he replaced. With a non-plastic one.
Old Jan 2, 2016 | 08:35 AM
seamonkey420's Avatar
seamonkey420
late reply here but i'm at 46K miles on my 2013 S Coupe and (knock on wood) so far zero issues. i owned mine from .1 miles on it and have a very specific break-in process and only this last oil change cycle did i have to add any oil. however i also went about 7000 miles too when i normally do 'an on my own dollar mid cycle change'.
N18 engine here.
Old Jan 2, 2016 | 11:44 AM
05r50's Avatar
05r50
Thanks for asking for advice and guidance. The statement above is really the most telling in where you might be headed.
These cars are notorious for having very expensive problems that can be somewhat avoided when given proper care and attention. Oil consumption is a big deal. There are tons of threads on this and other forums. Bottom line is that the turbo based models consume oil and MINI is OK with that. They even say it is expected to consume a quart every 1000-1500 miles or something similar.
So if your car was down 3 quarts of oil (in a 4.4 quart system) and there was no puddle under the car either at home or at work, then I can guess that you very rarely if ever check the oil level. You can do that with a Honda. Not so much with a MINI.
Rule of thumb on the R56 cars has been to check the oil and keep it full between changes. Also don't listen to MINI and go 10,000 miles or more between changes. Even if you don't do DIY stuff a $70-95 oil change is cheaper than a replaced motor.
Check around for a better priced MINI shop. It is worth driving miles to have someone take proper care. I've driven 3 hours one way to take my R56 JCW to a top notch shop. Well worth it.
Start checking the oil every fill-up or every 2 fill-ups. Learn how to read the dipstick (its crappy and can give you false hope if you don't read it right). There are plenty of threads on how.
Another issue with these engines has been carbon buildup on the valves. Plan on $350-800 every 20k-30k miles depending on driving style and fuel type. The R58 has had better results than the R56 but it is a direct injected motor and will have carbon buildup just maybe not as much.
You are doing the right thing. Asking questions so you can make informed decisions. I still love the brand but I realize it means that I have to keep a rainy day fund for repairs and I have to give it more attention than my kids Honda/Toyota cars. I am ok with that.
Old Jan 4, 2016 | 12:21 PM
That's a good move and knock one major one off the list.
Scm68
Jan 27, 2016 12:33 PM
semibreve42
Oct 2, 2015 09:06 AM
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
jennster
Sep 28, 2015 06:19 PM
gnhovis
Sep 28, 2015 04:07 AM
