R56 2009 R56 Horn stopped working.
Old Nov 10, 2015 | 05:31 PM
thadscottmoore's Avatar
thadscottmoore
any suggestions? I have checked the fuse and connections... hear a click in the passenger side when pressing on steering wheel center...
Old Nov 10, 2015 | 05:44 PM
AZdsrt's Avatar
AZdsrt
Should be easy to troubleshoot. Disconnect the wires at the horn, apply volt meter and see if it gets juice. If so, probably the horn. If not, probably the relay or switch in the steering wheel..
Old Nov 10, 2015 | 06:35 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've actually seen the horns fail already. Put a volt meter on the horn connector and make sure it gets the voltage. If it does you know the horns have failed, if not you got more diag to do.
If they are failed go with the Hella kit we have they are louder and fit great.
http://www.waymotorworks.com/hella-horn-kit-118db.html
Old Nov 12, 2015 | 07:42 AM
set in right be hind the bumper in front of the wheel well.
61332753032 is the low tone horn.
http://www.ecstuning.com/Search/SiteSearch/61332753032/
61332753033 is the high tone horn.
http://www.ecstuning.com/Search/SiteSearch/61332753033/
Another option is to go with the Hellas: Which are very similar in design to OEM.
http://www.ecstuning.com/Search/SiteSearch/UN6628500/
or Air trumpet kit if you really want to be loud.
http://www.ecstuning.com/Search/SiteSearch/UN6627400/
Thanks[/QUOTE]
Old Nov 12, 2015 | 12:09 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
+1. For Genuine replacement horns, 61332753032 low pitch and 61332753033 high pitch.
888.280.7799 | 6am - 5pm PST
Mar 4, 2019 06:21 AM
Mar 3, 2016 06:46 PM
JCWCM
Dec 31, 2015 06:44 PM
Oct 29, 2015 07:52 AM
Oct 28, 2015 10:47 AM
