FS:: Bridgestone Blizzak LM-60 RFT Winter Wheel & Tire set - 205/45 17
Category: Wheels & Tires
Price: $550
Part fits (you may select multiples): R50, R52, R53, R55, R56
Location (Region): Midwestern
Local pick-up only in Lake in the Hills, IL 60156. Might drive to meet buyer up to 50 miles. Cash ONLY.
For $550 you can own a complete set of Bridgestone Blizzak LM-60 RFT Winter / Snow tires 205/45 17 mounted on R105 Crown Spoke Mini Cooper wheels ready to bolt on. Wheels / tires are balanced and have TPMS fitted. These came off my 2009 R56 Mini Cooper S. Used for only 1 1/2 seasons. They will fit the Mini Cooper R56: "Mk II" Mini Hatch/Hardtop range (2006--2013). They may also fit the Mini Cooper R50: "Mk I" Mini One & Cooper (2001--2006), R52: "Mk I" Mini Convertible (2004--2008), R53: "Mk I" Mini Cooper S (2001--2006) & R55: "Mk II" Mini Clubman (2007--2014).
Bridgestone Blizzak LM-60 RFT is Bridgestone's Performance Winter / Snow run-flat tire. These tires cost $870 when new in Dec 2013.
Tires are in great shape, no problems, no punctures, no plugs or fixes. Tread depth on 2 of the tires is 6.2mm - 8/32nds". Tread depth on the other 2 is 5.5mm - 7/32nds".
Wheels are straight and true. They have some curb-rash and are in good general condition. No bends or leaks. I sold my Mini in the spring and so do not need these any more.
Tires: Bridgestone Blizzak LM-60 RFT 205/45-17
Wheel Specs are:
Offset: ET 48mm
Bolt Pattern: 4x100
Centerbore: 56.1mm
smdmini
Oct 7, 2019 06:05 AM
