R50/53 slow start
Old Oct 22, 2015 | 02:08 PM
Liqyellow03's Avatar
Liqyellow03
slow start
Hello everyone. Ive been on this site since i got my r53 in 2013. I never shot any pucs of it for people to see yet (slacking). So far ive put on alta's 17% pulley and tensioner stop. It had a borla stainless cat back, alta air diverter, and carbon intake system(dont know who makes it) on it when i bought it. I started buying suspension parts. Heres what she looks like
Konig lace 15" aero skirts some front lip i found on ebay and cowl scoops
Water dipped down tubes and custom installed aux port in switch blank
Water dipped door handles
Custom 8" sub box. Amp is hidden on other side
Alta air diverter cravenspeed dip stick carbon intake
Parts acquired so far
Old Oct 22, 2015 | 02:18 PM
bavmotors's Avatar
bavmotors
Where did you get that intake? Never seen one before. Car looks good!
Old Oct 22, 2015 | 02:25 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Digging the interior bits and good job with the sub install. What suspension parts did you go with? MINI looks very clean BTW.
888.280.7799 | 6am - 5pm PST
Old Oct 22, 2015 | 02:54 PM
Liqyellow03
No markings that i ever found on the intake system
And im trying to stay with all alta parts minus coils and front sway bar since they dont make one
Old Oct 22, 2015 | 02:55 PM
Liqyellow03
Damn right she is clean. 2003 with 126k lol. My second baby
Old Oct 22, 2015 | 02:56 PM
bavmotors's Avatar
bavmotors
That auxiliary placement is cool how did you do that?
Old Oct 22, 2015 | 02:57 PM
PelicanParts.com
Vendor
Well you take very good care of her. Be sure to post up some pictures once you get the suspension dialed in. If you need anything just give me a shout.
Old Oct 22, 2015 | 03:42 PM
Liqyellow03
Baymotors. I pulled the switch panel out and too it apart drilled a big enough hole then tucked the extra wire
Pelican i will keep in touch. It will be a slow process because i want to have all the parts at one time so im in and out in one shot
Old Oct 22, 2015 | 03:53 PM
Liqyellow03
Im starting to debate on getting rid of the chrome just not sure yet
Old Oct 22, 2015 | 04:37 PM
bavmotors's Avatar
bavmotors
Old Oct 22, 2015 | 04:42 PM
Liqyellow03
Baymotors if you want to see pics i can pull it out this weekend so you can decide if you want to put it there
Old Oct 22, 2015 | 04:43 PM
Liqyellow03
It is kinda tricky with all the switch springs and stuff inside it
Old Oct 22, 2015 | 04:50 PM
Liqyellow03
Came out great but a big pain in the ***
Old Oct 22, 2015 | 11:47 PM
atenzany62's Avatar
atenzany62
nice mods so far, liking the interior bits
Old Oct 23, 2015 | 02:55 AM
bavmotors's Avatar
bavmotors
thanks, I'll figure it out though.
Old Oct 23, 2015 | 07:22 AM
Looks like you have done so custom work on it. Seen that top lid on the CF intake before from japan , forget who makes it.
Looks like the factory aero kit side skirts also, nice find.
Old Oct 23, 2015 | 04:28 PM
Liqyellow03
Factory skirts were on it along with the intake and borla exhaust. Also had 18" ADR wheels (completely shot) car had 89k on it when i bought it and was very well taken care of. I have the original purchaser info when it was bought new in Minnesota by a woman
Old Oct 24, 2015 | 07:56 AM
Liqyellow03
Does anyone have any feed back on the h&r sway bar set? 27mm front and 19mm rear. Also megan ez strret coils. Thanks
Old Oct 24, 2015 | 10:23 AM
Liqyellow03
Just dropped off the control arm brackets and psrs at the machine shop. One more step closer
Old Oct 25, 2015 | 02:09 PM
OneSlowMini's Avatar
OneSlowMini
Clean Mini looks great
Old Oct 25, 2015 | 03:12 PM
Liqyellow03
Old Oct 25, 2015 | 06:07 PM
Kahnfucious's Avatar
Kahnfucious
19mm rear isn't much bigger than stock - Better to go with 22mm on softest setting and move inward from there.
Not a lot of people actually have experience with upgraded front sway bars because it is such a huge pain in the *** to install - good to do since you are dropping the subframe for other parts anyhow
Old Oct 26, 2015 | 04:06 AM
Liqyellow03
That is why i plan on replacing everything while its out. Is there any point in using a 27mm front thats non adjustable?
Old Oct 26, 2015 | 05:03 AM
Kahnfucious
I'm not too sure - Probably depends on your uses - track vs. street. Just be careful with how stiff you set everything. Unexpected over-steer won't be fun
Old Oct 26, 2015 | 03:06 PM
Liqyellow03
Got these back today
