F55/F56 Torque values
Old Oct 1, 2015 | 02:04 PM
MGBill1186's Avatar
MGBill1186
Torque values
Does anybody know the torque values of the engine oil drain plug, oil filter housing and oil filter housing drain plug. When I changed the oil the filter housing and drain plug seemed awfully tight. So I ran them up snug, but wonder if I Should torque them to a higher setting. Thanks
Old Oct 2, 2015 | 06:09 AM
papawhiskey's Avatar
papawhiskey
I know the filter cover is 18 ft lbs or 25 Nm. I don't know about the other two but I'd like to know those also.
Old Oct 2, 2015 | 06:54 AM
MGBill1186's Avatar
MGBill1186
Thanks for your info... That's the torque that I was able to find out by searching other threads on this site. Also I found that the torque value on the drain plug is 22 ft. Lbs or 33 Nm. Hope this helps you. Thanks again for your help Papawhiskey.
Tires, Wheels & Brakes
Oct 1, 2015 08:55 AM
pkillur
Sep 30, 2015 10:51 AM
EVMini
Sep 28, 2015 10:20 AM
Nicefeet
Sep 27, 2015 11:14 AM
