R50/53 Shift knob size?
You simply pull it off of the top, it has a special notch that snaps on the the top of the stick. I bought a compression style stick to put on mine and it worked fine. As far as how large the hole needs to be, pull your stock **** off and measure it I suppose.
Please open your sunroof...
Then pull it off...trust me...open the sunroof if you have one.... When you are yanking hard, and it releases...your hand and the **** will fly up...In your hand, and hit the window...and hurt like hell...
What type of **** are you going to replace it with? I changed mine out for a cue ball.
$17 and fit without any of the adapters that came with it. Just be careful because the pointy sets crews on mine were digging into the plastic making it wiggle, use blue thread lock.
There is a DIY here that can help with the removal of the **** if needed. Shift **** options here as well.
888.280.7799 | 6am - 5pm PST
Watch when you pull it off if you have a glass roof ( open it ) or dont hit yourself in the face when it comes off. Its happens.
Grizld700
Dec 30, 2015 10:47 AM
nayr924
Sep 8, 2015 02:41 PM
SneedSpeed
Sep 2, 2015 05:34 AM
