Mini Cooper Air Filter & Oil Filter Factory Application Guid
Mini Cooper Filter Factory Application Guide. Listings for MINI original equipment Air Filter, Oil Filter, and Cabin Filter.
There is nothing more important than regular routine maintenance for prolonging the life of your MINI. MINI has recommendations for maintenance intervals but these are based on 'ideal' driving conditions - ie. long distance freeway driving. The average person drives their MINI in a mix of city and freeway driving. Some drive mostly in the city. In both of these cases, the factory recommended maintenance interval is too long! Change more frequently!
The Oil Filter Cannister Cover requires a larger socket that are typically not included in your standard socket set. If you need the socket, take a look at these:
See the guide below to help you identify the correct factory replacement filter for your MINI. (Click on the following link for the complete article.) http://new.minimania.com/Mini_Cooper...lication_Guide
- R50 & R53 Hardtop & R52 Convertible Oil Filter Housing Socket (low profile)
- R56 R55 R57 R58 R59 R60 R61 models Oil Filter Housing Socket
- F55 & F56 Hardtop Oil Filter Housing Socket
phrza81
Oct 10, 2015 11:37 PM
jrezzo
Aug 9, 2015 10:32 PM
M7Speed
Aug 6, 2015 01:48 PM
