Drivetrain removing heat shields for turbo cat ?
Old Aug 8, 2015 | 01:56 PM
rckrzy1's Avatar
rckrzy1
Since I will need to remove my DP and install Cat atleast 2 times a year has any one run the car with no shields ?
I'm thinking of putting a turbo blanket on turbo and using a ceramic coated DP.
Now I can also titanium wrap my DP after ceramic coating if that is needed.
I just want to be able to get to stock cat config for emission testing and for warranty work.
I'm not sure if wrapping a ceramic coated DP is needed or even good idea ?
Be nice to reduce under hood temps , I think a turbo blanket and ceramic DP would be enough but ? Not sure.
Old Aug 9, 2015 | 11:06 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Do NOT run it without the heat shields in place. We've seen this done before and you end up with a melted valve cover.
Old Aug 9, 2015 | 11:09 AM
rckrzy1's Avatar
rckrzy1
Top and bottom ? I've not ever looked but I think it has upper and lower ?
Old Aug 9, 2015 | 07:35 PM
rckrzy1's Avatar
rckrzy1
Even if I put a turbo blanket on as well or is the heat from the manifold the issue
Old Aug 11, 2015 | 06:06 PM
minivinnie92's Avatar
minivinnie92
I have been running ceramic coated 3" catless dp since last August no shields what so ever I auto x and 1/4 plus daily drive my R56 no issues
Sexual Chocolate
Mar 31, 2019 08:02 PM
theunlimitedone
Aug 31, 2015 08:17 PM
rckrzy1
Aug 26, 2015 09:12 AM
damncajun
Aug 17, 2015 08:25 PM
