R56 R56 - Removing the Intake VANOS Solenoid.
Old Aug 2, 2015 | 05:10 PM
Andrew Pepper's Avatar
Andrew Pepper
What's the procedure for removing the Intake VANOS solenoid from a R56 Cooper S, N18 engine ?
I removed the airbox, but I don't seem to be able to find the Torx bolt that holds it in. What's the best method of attack.
TIA
Andrew
Old Aug 2, 2015 | 05:38 PM
cerenkov's Avatar
cerenkov
You only can feel in with your finger, it's on the driver side almost directly inline with the first intake runner.
Old Aug 2, 2015 | 05:40 PM
cerenkov's Avatar
cerenkov
The procedure is:
Disconnect the plug
Remove the bolt
Remove the solenoid
If it is hard to remove then try rotating the valves in the cylinder head it may make it easier.
Old Aug 2, 2015 | 05:45 PM
Andrew Pepper
Thanks ... I'll give it another go finding the bolt. There seems to be a plastic wiring chase in front of where I would expect the bolt to be. Maybe it's time to dig the mirror out and see if that'll help.
Old Aug 2, 2015 | 05:47 PM
cerenkov's Avatar
cerenkov
Yes it is right below that plastic chase.
09R56
Nov 16, 2022 10:49 AM
Svejk
Feb 24, 2019 12:18 PM
bobbiemartin
Jan 20, 2016 05:28 PM
