:: ECS Tuning :: R56 Ziza LEDs | New* R53 Aluminium Thermostat kits | NM Eng. F55
Old Jul 23, 2015 | 01:50 PM
MINI R56 Ziza LED Interior Lighting Kits
ECS is happy to offer its largest assortment of Ziza LED lighting options for your MINI R56. Now it's easy to add the clean white brilliance of LEDs to your favorite car.
Light a little. Light a lot. Select individual bulbs for your lighting needs, or purchase a convenient package containing enough LEDs for all interior light locations.
Then move outside your car where license plate LEDs give your car a crisp white glow after dark.
Our detailed online tutorials show you how easy it is to brighten your car--and your driving experience, with Ziza LEDs.
Ziza: Task Lighting to Total Makeover
Fits:
R56 MINI Cooper /S/JCW (2007-2010)
Click HERE For LED options
Fits:
R56 MINI Cooper /S/JCW (2011-2013)
MINI R52 Aluminum Thermostat Replacement Kits
It is Important to maintain the proper engine operating temperature to avoid engine overheating and costly damage.
Prevent cooling issues before they begin with a Hamburg-Technic Germany Cast Aluminum Thermostat Housing For Your R52.
If your MINI has high miles or has an unreliable thermostat, replace all the critical components at the same time for added assurance.
The OEM plastic thermostat is a common source of leaks for the supercharged MINI - A cast aluminum housing with an updated gasket design is the ultimate solution.
Stay Cool
Fits:
R52 MINI Cooper Convertible S/ JCW (2005-2008)
Click HERE For aluminium thermostat kit
[/URL]
MINI R53 Aluminum Thermostat Replacement Kits
Prevent cooling issues before they begin with a Hamburg-Technic Germany Cast Aluminum Thermostat Housing For Your R53.
Stay Cool
Fits:
R53 MINI Cooper S/ JCW (2002-2006)
[/URL]
Cooling System Refresh Kits
Replacing cooling system components and performing a proper coolant flush will ensure a long life for your cooling system.
Most of the cooling system components are exposed to very high temperatures and repeated thermal cycling. Heat-hardening causes warping and cracking that leads to coolant loss and possible engine damage from overheating.
Avoid headaches altogether and replace all problematic items at once to keep your cooling system running efficiently.
Keep Your Cool
Fits:
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible (2005-2008)
Click HERE For cooling kits
Cooling System Refresh Kits For Your MINI R52 R53
Keep Your Cool
Fits:
R53 MINI Cooper S / JCW (2002-2006)
Click HERE For cooling options
R50/R52/R53 MINI Euro Cubby Tray
This snap-in storage cubby tray is a fast and easy way to add extra storage for small items to your MINI R50 R52 R53.
Straight from the Euro market, the unit comes in panther black to match the original dash panels. The grippy rubber tray liner helps keep small items from sliding around.
A spare rectangular hole in the panel accepts a stock switch so you can control any accessory you choose. Or, cover the hole with the blind plate included in the kit for a smooth appearance.
Cubby Buddy
Fits All Gen 1 MINIs:
R52 MINI Cooper Convertible / S / JCW (2005-2008)
Click HERE For the cubby kit
MINI F55 Cooper NM Engineering Performance Products
NM Engineering's primary goal is to improve the driver's motoring experience without changing the essence of what makes MINI a MINI.
Now available through ECS Tuning, browse through the stunning catalog of NM drivetrain, powertrain, and aesthetic upgrades for your MINI F55.
The NM Hi-Flow Induction Kit comes in three colors, all increasing air flow to your engine for better throttle response and power. NM also offers an array of beautiful satin black, gunmetal, and satin gunmetal wheels.
NM structural enhancements include a 22mm Adjustable Sway Bar and Control Arm Kit.
Authentic NM
Fits:
F55 MINI Cooper/S (2014+)
Click HERE For NM options
Aug 12, 2015 01:24 PM
Aug 7, 2015 07:12 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
