R56 Abs control unit supply fault 5DAA
Old Jul 14, 2015 | 01:17 AM
scrappyloz's Avatar
scrappyloz
I have the abs light, traction light and park brake light all illuminated on my dashboard. The lights are on nearly every time I start the car but very rarely for one journey everything will work fine with no lights.
I have the fault codes
5daa control unit power supply
5e2c control unit power supply
5dd4 control unit internal fault
If I clear the faults they all disappear for a while except 5daa which won't clear.
I have checked all fuses and they are fine.
I believe I'm looking at needing a new a abs/module. Is this the case?
Old Jul 14, 2015 | 10:02 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
seen that fault before and it did take a new module to fix it, and it was the entire pump/module. Just the electric part didn't fix it as we tried that to save cash.
Old Jul 14, 2015 | 11:13 AM
scrappyloz's Avatar
scrappyloz
cheers for the reply. are the units coded or are they plug and play?
Old Jul 14, 2015 | 08:21 PM
WayMotorWorks
Vendor
New units come blank and need to be coded to the car. If you can find a used one it can be recoded much cheaper.
Old Jun 1, 2019 | 07:44 PM
JohnL's Avatar
JohnL
My 2007 MC has the same problem any luck on the fix
Red brake light traction control and abs..
With a pretty code to go along with it
Old Jun 2, 2019 | 12:59 AM
scrappyloz's Avatar
scrappyloz
Hi this was a long time ago but i ending up changing the unit and recoding it using ncs expert. if i remember correctly
xpunisherx
Nov 27, 2015 03:32 PM
jesterofatlas
Sep 4, 2015 11:23 PM
Suspension Products
Sep 3, 2015 09:41 AM
Ntety
Sep 2, 2015 08:39 PM
